575 trunk release button works intermittently | FerrariChat
Discussion in '456/550/575' started by bellwilliam, Dec 15, 2018.
  1. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    398
    The electronic button in the cabin for the trunk works intermittently (50% of the time) Trunk opens just fine when pulling the emergency release strap on the rear deck.
    What should I check first for I termittent issue? Thanks.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Remove switch and and check switch function with ohm meter. If switch is fine, probably solenoid.
  3. tazandjan
    38,087
    May just be an adjustment issue, too. Have someone push the button while you watch what is happening.
    bellwilliam and Dave rocks like this.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    My 456 truck does not pop up. The solenoid disengages but I have to get my fingernails underneath the trunk lid to get it up. Pretty far down my list right now but curious about your issue and resolution.
  5. GTS Bruce
    GTS Bruce Pisses in your Cheerios
    Oct 10, 2012
    793
    Orchard Park NY
    Bruce Roche
    Never use the button. Easier to use the pull handle after you're out and your going to get out anyway.
  6. tazandjan
    38,087
    Bruce- I always use the button and have for 10 years. Those cables are known to stretch and break, so I would use them for back-up only.
    wbklink likes this.
  7. JohnnyRay
    JohnnyRay F1 Rookie
    2,932
    Central FL/NW WI
    Its likely the switch. I had to replace mine...
    bellwilliam likes this.
  8. GTS Bruce
    Oct 10, 2012
    793
    Orchard Park NY
    Bruce Roche
    Good thought
  9. drrob
    drrob Rookie
    Apr 11, 2009
    18
    North Alabama
    Replaced switch also and it fixed the same problem.
  10. bellwilliam
    Oct 25, 2014
    398
    Does the switch just pop off?
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The body of the switch has spring steel clips that hold it in place. Use a very thin metal pry tool (plastic are typically too thick) and get the pry tool under the lip of the switch and then pry it from the trim.
    In this photo you can slightly see the one of the metal clips.
  12. bellwilliam
    Oct 25, 2014
    398
    Dave: thanks !!
    Dave rocks likes this.
  13. 00 550
    00 550 Formula Junior
    Oct 20, 2009
    412
    FL
    That guy
    Just take switch apart and rub sand paper on contacts takes 5 minutes, worked for mine
  14. 00 550
    Oct 20, 2009
    412
    FL
    That guy
    Oops, sorry. Thought it was a 550 button. Happy Hollidays!
