575M - F1 to Gated 6 Manual Conversion | Page 17 | FerrariChat
Discussion in '456/550/575' started by dhalperin13, Apr 3, 2021.
  1. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Robin, my understanding now is that there is a 3d printed plastic bushing in the tower that is not responding well to the heat from the exhaust. I had a bushing fail on my gated 360. It seems this was common on the manual 360s
    https://www.ferrarichat.com/forum/threads/360-shifter-bushing-repair.249934/
    However, even when the bushing completely failed, I didn't have the resonance/vibration that I do in the 575. Still awaiting resolution from EAG on this.
    brogenville and Ferrari55whoa like this.
  2. brogenville
    brogenville Formula 3
    2,308
    Robin
    The bushing on the 360 wears and makes the gearstick feel loose. That’s just through friction through as it’s all inside the car. On the 575, the exhaust is quite close, but it’s behind an upper and a lower heat shield, and then the turret should be sealed itself from dust, which should further protect it. All depends on what they’ve used, but clearly you need to use fairly high temp plastics to resist the heat.
    dhalperin13 likes this.
  3. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    The turret and shift gate do get hot to the touch. I am not sure what sort of insulation, if any, is currently installed. In the repair kit (for the resonance), EAG indicated that they would be sending me some insulating tape to wrap the section of the exhaust near the shift turret along with a new bushing and brass bearing.
    In my ongoing pursuit of motoring perfection (thanks Joe) and based upon recommendations from @360trev and @tazandjan, I have a set of Supersprint exhaust connecting pipes ordered to round out the Fabio exhaust system. A week from today, I'll be taking the car for its first visit to a shop other than EAG since I've owned it. Other than a multipoint inspection, I hope to have the MSW Sway bar, Steering ECU, Supersprint pipes, and fingers crossed…EAG repair kit installed. Wishful thinking on the two latter items as I just ordered the SuperSprint pipes yesterday and I don’t have an ETA on the EAG repair kit yet.
  4. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Car is in the shop now being fitted with the EAG repair kit. Hoping this resolves the resonance/vibration issues…
    interesting timing… @458Lvr (I think that’s Normal Guy Dan) posted a cool video on adjusting the 575 shift linkage.
    brogenville and Condor Man like this.
  5. Kevin Bird
    Kevin Bird Karting
    Jun 20, 2019
    155
    South Cotswolds, UK
    Kevin Bird
    Also interesting, he's said on here that he is no longer associated with EAG
  6. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,475
    Los Gatos, CA
    Eric
    Perhaps quite a few guys?
  7. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    I would love to hear the story…or maybe not. :eek:
  8. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    I just watched the video and missed that.
    When does he say it?
  9. Condor Man
    4,938
    Los Angeles
    I wonder how he is going to prevent it from coming lose again?
    He did say that he is going to tighten the piss out of it...... Perhaps some semi loctite?
  10. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,689
    Honestly, if OEM parts aren’t used, I can only see headaches with these conversions…..
    Condor Man and Kevin Bird like this.
  11. Kevin Bird
    Kevin Bird Karting
    Jun 20, 2019
    155
    South Cotswolds, UK
    Kevin Bird
    Condor Man likes this.
  12. Condor Man
    4,938
    Los Angeles
  13. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    714
    Toronto
    Ryan
    About the shifter adjustment, unless the EAG kit is different from the OEM parts, that is not where you adjust the shifter, at least that's now where I adjust it on my 550. There is a coupling farther forward with 2 pinch bolts that you can use to make shifter adjustments.
  14. Condor Man
    4,938
    Los Angeles
    That’s interesting.
    May the Horse be with you
  15. Ferrarienthusiast71
    Ferrarienthusiast71 Formula Junior
    721
    Charlie
    I test drove a swapped manual trans and it didn’t feel right, definitely not the same crisp smooth way that the original factory manual transmission felt, it really was a day and night, I’m going to stick with a 550
  16. Condor Man
    4,938
    Los Angeles
    Which car did you drive?
    Who did the conversion?
  17. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    I will say, everyone that drives mine seems to want to buy a 575. Gated, Fabio Exhaust, Trev Tune, MSW bits…magical combo :cool:
  18. Condor Man
    4,938
    Los Angeles
    #418 Condor Man, Sep 15, 2023
    After driving my 575 in manual today, I had the opportunity to drive a 599 GTB owned by a member here in converted OEM style manual and it was absolutely off the charts and perfect in every way!
    The car free revs like my 992 GT3 and the whole package was just brilliant.
    Needless to say my 599 is now headed over to go get the manual conversion.
  19. FerrariIcona
    FerrariIcona Formula Junior
    294
    Yingli Cheng
    Are you using factory parts or EAG aftermarket parts?
    As for the 575, using all OEM parts takes away the any questions or doubts about proper OEM style working and feel.
  20. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    It's a combination of OEM and EAG reproduction of OEM.
  21. FerrariIcona
    294
    Yingli Cheng
    Which OEM parts did you find were no longer available?
  22. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Hello everyone, I wanted to take some time to update everyone on my car and also shed some additional light on the EAG situation. As a customer of EAGs, for over two years, I had my suspicions as to what was going on over there. Some of the things that I have learned could make for the premise of a Hollywood blockbuster. The stories I hear are somehow both not surprising and totally unbelievable!
    First, I’d like to express my sincere gratitude to John Henkel and his company Macchina Motorwerx (MMW) for supporting me (and my car) through this process. John is running MMW, and while working with EAG, he was responsible for making sure my car was delivered back to me.
    I’d also like to thank my friend James LaPorte, owner of Apex Motorsports in Buffalo Grove IL. James has been working with John and MMW to fine tune the conversion. James graciously hosted MMW techs into his shop this week.
    Finally, I’d like to thank Billy and Mike. John asked Billy and Mike, two of the technicians that left EAG for MMW, to come to Chicagoland to finish the conversion properly. Mike and Billy left their families for the week to work on the car at Apex while staying at my home.
    I feel extremely fortunate that this team has gone above and beyond in their support of getting this project across the finish line!
    By spending quality time with Billy and Mike, I learned of some fascinating stories. Most importantly for the purposes of this thread and subject matter…these two technicians are best friends, business partners (owned and operated their own shop) and were directly responsible for getting over 45 back logged Ferrari’s out of the door at EAG over the year that they spent with that company. I’m encouraging them to tell their story on a podcast or to a screenwriter, because, as I mentioned, it is somehow both unbelievable, and not surprising. As those are their stories to tell, I’m not going to get into it…but I can say that they do have some amazing records and photos to support their story. It’s really incredible.
    Now for great news…I took the finished car home last night and it is dialed in! I will share videos as the weather improves, But the modifications that MMW has made to the kit seem to have completely eliminated the vibration issues that I was experiencing. What an amazing journey this has been..and what an amazing car I have! I feel so fortunate!!
  23. Ferrari55whoa
    3,475
    Los Gatos, CA
    Eric
    This is fantastic!
  24. ttforcefed
    ttforcefed F1 World Champ
    19,278
    nice to hear you are happy with the car, glad it didnt disappoint!
  25. Mirek
    Mirek Formula 3
    1,513
    Los Angeles, CA
    Mirek
    Would you do it all over again ?
