599 GTB Spacers and What Size | FerrariChat
Discussion in '612/599' started by Jkay, Jan 24, 2017.
  1. Jkay
    Jkay Karting
    Jan 9, 2017
    242
    #1 Jkay, Jan 24, 2017
    Hello All
    Apologies if this has been covered but I couldn't find exactly what I was looking for when I searched
    Planning on lowering the 599 on its original suspension by 10-15mm, and adding wheel spacers with the original, challenge style 20" wheels.
    Taz mentions Hill Engineering spacers are best.
    What size spacers are best ? 25mm all around ? Don't want to go too aggressive (and do any damage and ruin handling) but just want to fill those wheel arches better.
    Thank you
  2. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
    #2 papataori, Jan 25, 2017
    Vivid Racing here in the states told me that Novitec recommend 15mm front and 20mm rear on a 599 with the 20" Challenge wheels. For my 2009 599 (stock ride height & 20" Challenge wheels), I decided on 10mm front and 20mm rear but don't know if I'm completely satisfied with the stance. I've ordered 15mm all the way around to really dial in what I think looks best. I personally thought the 10mm in front was still tucked too much and the 20mm rear may even stick out past the fender ever so slightly. IMO, 25mm would be too wide. For the Type 1 spacers, make sure to order with new longer wheel bolts. Hope this helps.
  3. Jkay
    Jkay Karting
    Jan 9, 2017
    242
    Thanks Will.
    I don't want to stick out past the rear fender and go so extreme,but just want it to fill those arches nicely.
    Noted re the front, I'll definitely go at least 15mm
    You don't happen to have pictures of your spacers (15mm front/20mm rear) fitted by any chance ?
    Thank you
  4. DZ-96
    DZ-96 Formula 3
    1,782
    South Germany
    Daniel
    #4 DZ-96, Jan 25, 2017
  5. DZ-96
    DZ-96 Formula 3
    1,782
    South Germany
    Daniel
  6. DZ-96
    DZ-96 Formula 3
    1,782
    South Germany
    Daniel
    #7 DZ-96, Jan 25, 2017
    I hope it helps you.
    If you need high res photos, feel free to contact me.
    Daniel
  7. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    #8 Roupin, Jan 25, 2017
    20mm spacers front/rear.
    Lowered to lowest setting on HGTE springs. Don't know the exact amount but would guess about 25mm.
    Rear tires are 315 wide Michelin Pilot Supersports.
    Mark Carbone likes this.
  8. Jkay
    Jkay Karting
    Jan 9, 2017
    242
    Thank you. Those all look great!
  9. Jkay
    Jkay Karting
    Jan 9, 2017
    242
    Love it Roupin. Are your rears 315/35/20 or 315/30/20? Thanks
  10. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    315/35/20, the F12 size.
    The tires are amazing. I can nearly flatfoot 1st gear and maintain traction (in warm weather). My (previous) Pirellis used to spin well into 2nd.
  11. Ferrrrarrrri
    Ferrrrarrrri Rookie
    Aug 7, 2004
    36
    SE PA
    Barry
    That looks awesome!
    Any chance you have a shot from the rear that shows the tire width?
  12. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    #13 Roupin, Jan 26, 2017
    I don't have any from exactly the rear but you can get an idea from this shot.
    Visually it's hard to discern a 315 from a 305 tire. The 335-355 tires are the ones that look dramatically wider.
  13. v35
    v35 Karting
    May 15, 2013
    190
    Los Angeles
    Aaron
    That looks amazing, I'd love the same setup. Would you mind sharing which company spacers you went with and which shop you had handle the lowering of the factory coilovers and alignment? Thank you!
  14. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    I went with a local raceshop for the spacers, but in hindsight I would buy a set from Novitec instead. I tried to save time buying locally but the first set didn't mate with my wheels and the second set took a few weeks to ship out.
    All the work was done at my local Ferrari dealer. Since the suspension was coming apart I also upgraded the rear sway bar to the 599Aperta rear bar. Slightly thicker than HGTE.
  15. francars
    francars Karting
    Nov 28, 2006
    109
    Bay Area, CA
    Francisco
    That is an awesome pic! I think my HGTE needs to be lowered more... hmmm
  16. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    They set the front end as low as possible and adjusted the rear for a very slight rake per my request.
    Bring it down!
  17. Ferrrrarrrri
    Ferrrrarrrri Rookie
    Aug 7, 2004
    36
    SE PA
    Barry
    It does look amazing --well done!
  18. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
    #19 papataori, Feb 13, 2017
    Hey Jkay,
    Apologies it took me so long to get pics up here. Had a lot of work done at my local mechanic and was out of town for a while. Below you will find pics of our 2009 599 at stock ride height with the 20" Challenge wheels. ~11k miles. New Michelin Pilot Super Sport tires installed (245/35/20 K2 for front, 315/35/20 K2 for rear). New tpms sensors. 15mm Hill Engineering spacers on all 4 corners with new longer Hill bolts. Ordered directly from Hill for best pricing.
    I preferred the 15mm all around instead of the 10mm front and 20mm rear Novitecs that I originally bought. Pictures don't quite show as well as in-person. In-person it looks a bit more aggressive than in pics. I personally thought the 20mm rear looked a bit too aggressive in-person. Though, in others' pics above, they and the 25mm look really nice.
    I also went ahead and replaced ball joints and ball joint boots at all four corners, as well as full tie-rod assemblies on rear and tie-rod ends at front. The original lower ball joint boots had cracked and the ball joints were corroding a bit. Rear tie-rod assemblies had completely seized together making alignment impossible. Decided to go ahead and redo everything with new, permanent and very high quality parts from Hill Engineering ordered directly from Hill. With all new mods including tires and an alignment, it feels like a completely different car in the best way possible.
    Hope all this helps.
    Best,
    Will
  19. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
    #20 papataori, Feb 13, 2017
  20. MrF355
    MrF355 Formula Junior
    Mar 4, 2008
    495
    Kimi
    JKay, if you check with RMS you will find that spacers are not legal in NSW and all other States and Territories as well. You will also have potential problems with your insurer.
  21. Jkay
    Jkay Karting
    Jan 9, 2017
    242
    Thanks for that papataori
    Looks just right i think, not too aggressive and also better than stock
    Just looked this up and yes you're right. Australia never fails to amaze me with their road rules all in the name of "safety"
    I'm told recaro seats are illegal here too, govt prefers everyone to be in camrys
  22. MrF355
    Mar 4, 2008
    495
    Kimi
    Regulations came out before the Camry. As for Recaro seats being illegal,check with what seats are fitted to a 599.
  23. MaseratiCorse
    MaseratiCorse Formula Junior
    Nov 13, 2014
    472
    Melbourne, Australia
    Nicholas
    Do the 15mm spacers help handling?
  24. papataori
    papataori Karting
    Oct 24, 2007
    181
    Nashville, TN
    Will
    I doubt they help handling in any meaningful way...especially if keeping oem wheel and tire sizes. Spacers are more of an aesthetic modification. Changing to a superior tire setup, such as the MPSS, will change handling/feel.
