599 GTB Spacers and What Size | Page 3 | FerrariChat
Discussion in '612/599' started by Jkay, Jan 24, 2017.
  1. odf911
    odf911 Formula Junior
    Nov 30, 2013
    554
    London UK (Chelsea)
    Olivier
    Mine were 245 front I believe factory. I still have all these tyres actually as well as the HGTE wheels ...
    DZ-96 likes this.
  2. mmopar0521
    mmopar0521 Rookie
    Sep 28, 2020
    7
    Mike S
    My 2010 HGTE has 245/35-20 in the front and 305/35-20 in the rear
    DZ-96 likes this.
  3. DZ-96
    DZ-96 Formula 3
    1,890
    South Germany
    Daniel
    Hi Fernando
    I believe, not really softer.
    But i don't know.
    Drove the car in Oktober with Original height.
    Then, in April, the car was brought to the dealer with a trailer because of an oil leak.
    They fixed the oil leak and lowered the car.
    Daniel
    Makuono likes this.
  4. tazandjan
    39,020
    Daniel- One thing that might interest you is that the F12 has the same size wheels as the 599 GTO, and OEM tire sizes are 255/35 20 and 315/35 20.
    DZ-96 likes this.
  5. George Vosburgh
    George Vosburgh F1 Rookie
    Right, as recently discovered. I'm really a little gun shy of spacers because of what it does to the suspension. Am I correct in assuming that the suspension in the GTO and HGTE are similar to the standard 599? In other words, are wider wheels better than standard wheels with spacers???
  6. tazandjan
    39,020
    George- Affirmative, but you might need spacers on wider wheels, too, depending on offsets. The GTO and HGTE had stiffer springs and anti-roll bars than the std 599, plus shock/body ECUs to match. On the HGTE, it was only the rear bar, not sure about the GTO since I have not researched that.
  7. DZ-96
    DZ-96 Formula 3
    1,890
    South Germany
    Daniel
    Thanks Terry
    Good to know about the F12
    So, perhaps I go with the 255 and 315 I have.
    Tires and TPMS are nearly new, perhaps 3000 Km on them.
    I will think about until April.
    Daniel
  8. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    116
    Oregon
    Tom
    Reviving an old thread here. Just lowered the car to lowest setting in front (perch nut to sway bar) and rear to match wheel gap. I have just purchased a pair of HE 15mm spacers to fill the gap. I am thinking of bucking the trend and placing 20mm in the front and 15mm in the rear. From my perspective, visually, the front is where the larger spacer should go. Is this idea problematic for handling or alignment? Option 2 is to go 15mm all around.
  9. Condor Man
    Condor Man F1 Rookie
    4,936
    Los Angeles
    I just read this whole thread and I am a little confused as to what spacers to order for my 599 GTB HGTE.
    I just saw a 575 with 25mm on the rear and 15mm on the front and the car was so perfect in it’s stance. So to me that was an easy decision on the ordering front.
    For the 599 I was thinking 20mm at the rear and 15mm at the front.
    Any thoughts?
  10. tazandjan
    39,020
    You will need longer bolts with those spacers. The reason we use 25 mm on the rears for 575Ms is you can get Type 2 spacers from Hill that bolt to the hub and use the original wheel bolts. Since I have titanium bolts....
    Condor Man likes this.
  11. DZ-96
    DZ-96 Formula 3
    1,890
    South Germany
    Daniel
    With 22mm type 2 at the front and 25mm type 2 at the rear you can use stock bolts.
    22mm is minimum, the original 52mm bolts are about 21,5mm outside behind the rim hub surface.
    See my older post in this thread how it looks.
    I had 255/35 at the front and 315/35 at the rear.
    Works perfect.
    Capristo has spacers in 14mm and 17mm included longer titanium wheel bolts.
    Not cheap but included titanium bolts. The price is included a certificate which was important for me.
    Have a set here because i had it on my SF before i installed the Monza rims.
    Daniel
    clandestine and Condor Man like this.
  12. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    901
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    What is the effect of the larger sway bar on handling? Thanks
  13. tazandjan
    39,020
    Decreases understeer.
    bamaman likes this.
  14. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    116
    Oregon
    Tom
    I was advised by Hill to keep the spaces at 15mm all around, so that is what I did. The back looks great, but I feel the front could use a little more. Again, they advised me not to use larger (20mm) spacers in the front. Why, I don't know.
    I replaced the supplied longer lugs with titanium lugs from Acer racing to offset some of the spacer weight. They have a set of 20 with 17mm hex heads and at length to work with 15mm-17mm spacers. Overall, I am happy with the look of both the wheel offset and the new lugs.
  15. C4YES
    C4YES Formula Junior
    992
    Orange County, CA
    Todd
    I installed the thicker than stock rear anti sway bar, H&R, i didn't notice any difference.
  16. Condor Man
    4,936
    Los Angeles
    Did you have photos of your car?
    May the Horse be with you
  17. Condor Man
    4,936
    Los Angeles
    Thanks Daniel, I am little concerned with how far they stick out.
    I think that the 599 actually needs the same spacer for front and rear.
    So I am now thinking 15mm or and most 20mm front and rear.
  18. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    116
    Oregon
    Tom
  19. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    116
    Oregon
    Tom
    Condor Man and George Vosburgh like this.
  20. Condor Man
    4,936
    Los Angeles
    Thank you for posting these photos.
    Your wheels looks great and you should be happy with the result.
    Having stated this;
    It’s amazing with even 15mm spacers how there is still some room to go out further.
    Perhaps 20mm + 20mm is the magic number.
  21. Condor Man
    4,936
    Los Angeles
  22. bamaman
    Nov 27, 2015
    901
    Mobile Alabama
    Thanks - the spacers sure improve the stance of the car.
    Nine9Three likes this.
  23. Condor Man
    4,936
    Los Angeles
    This is really strange as I just ordered a set of 20mm all round from Hill and I did this over email.
    There was no mention not to purchase the 20mm.
  24. George Vosburgh
    I believe for 599 Hill uses 20mm, they make other spacers for other models.
  25. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    116
    Oregon
    Tom
    What they advised against was using the larger 20mm spacers in front and 15mm in the rear. On my gtb the 15mm spacer in the rear is near perfect and I did not want to go further out. The front however I felt would benefit from a thicker spacer. Overall, I am still pleased with the result.
