599 GTB Spacers and What Size | Page 4 | FerrariChat
Discussion in '612/599' started by Jkay, Jan 24, 2017.
  1. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    OK.
    I could say how they would advise against this.
    If you check out the red car in the start of this thread I think 20mm all round looks really good.
    Perhaps you want to try this?
  2. tazandjan
    39,318
    5 mm is 0.197", less than a fifth of an inch. Not too noticeable.
    DZ-96 likes this.
  3. Condor Man
    4,938
    Los Angeles
    My spacers arrive tomorrow.
    20mm all round.
    How easy are these to install by myself??
  4. Skidkid
    Skidkid F1 Veteran
    9,631
    Campbell, CA
    John Zornes
    If you can torque wheel bolts, you have this. BUT, you might need guide pins.
  5. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    Be sure that the spacer rear surface is sitting completely on the hub surface, also the wheel surface on the spacer front surface.
    In some rare cases problems are possible, if phases do not match, rim has smaller phase than spacer for example, or the depth of the center bore from the spacer is not deep enough and the center ring at the hub is longer.
    Be sure the hub fixing screws do fit correctly with the spacers holes, saw smaller spacer holes than hex of the screws for example
    Be sure the bolts are long enough but also not too long
    Sorry for my bad explanation, but for me it's hard to describe in english.
    Here an example of the mounting bolts which John described.
    I made for me 3 in titanium on a lathing machine in our company.
    Daniel
  6. Condor Man
    4,938
    Los Angeles
    Thank you Daniel,
    I went to the local tire shop and they girl behind the counter was a closer decent to an ape than most of us. Hence I didn't have them installed.
    Probably better for me as my Fabspeed Cat Bypass pipes arrive next week and my Forza valve switch just arrived, so I will take the car to Ferrari for them to fit everything at once next week.
    Stay tuned.
  7. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    955
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    What length bolts should be ordered from Hill for the 15mm spacers?
  8. Condor Man
    4,938
    Los Angeles
    They will advise when you order.
    May the Horse be with you
  9. Condor Man
    4,938
    Los Angeles
    I just checked mine and they were 72mm for 20mm.
    So I am guessing 67mm.
  10. tazandjan
    39,318
    Yup, OEM wheel bolts are 52 mm.
    Condor Man likes this.
  11. Kyle Stoffer
    Kyle Stoffer Karting
    Sep 23, 2019
    82
    Kyle R Stoffer
    Very easy to install. I can’t think of any issues…other than stripping a lug. Pretty standard work.
  12. Condor Man
    4,938
    Los Angeles
    vforvictory, tres55 and Nine9Three like this.
  13. George Vosburgh
    George Vosburgh F1 Rookie
  14. Condor Man
    4,938
    Los Angeles
    Thanks George,
    Yes I am going to have it retorqued at the end of the weekend too.
    George Vosburgh likes this.
  15. Condor Man
    4,938
    Los Angeles
    Hawkeye and 599_GTO like this.
  16. nota400
    nota400 Karting
    Nov 21, 2015
    82
    Spacer size and bolt length to install GTO wheels and tires on a GTB please?
  17. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    No spacers needed, bolt length original 52mm
    If you want you can go with 20mm at the rear (22mm system 2 also possible - so you can use original bolts), at the front no spacer necessary.
    Daniel
  18. nota400
    nota400 Karting
    Nov 21, 2015
    82
    Thank you.
  19. Hawkeye
    Hawkeye F1 Veteran
    8,243
    Condor Man and George Vosburgh like this.
  20. Condor Man
    4,938
    Los Angeles
    And????
    Where are rear photos???
  21. Nine9Three
    Nine9Three Karting
    Oct 24, 2017
    122
    Oregon
    Tom
    Is your rotor on the floor?!?
  22. Hawkeye
    Hawkeye F1 Veteran
    8,243
    Optical illusion, it's 8 inches or so off the floor, had to lift wheel 4 inches to get the hub aligned.
  23. Hawkeye
    Hawkeye F1 Veteran
    8,243
    Condor Man and DZ-96 like this.
  24. DZ-96
    DZ-96 Formula 3
    1,926
    South Germany
    Daniel
    Daytona
    550
    599
    Really great collection !!!
    And all in red, i love it.
    I wish i had the chance to drive a Daytona for one time in my life.
    Daniel
    Hawkeye likes this.
  25. Hawkeye
    Hawkeye F1 Veteran
    8,243
    The Daytona is really great, airbox is off and the twelve trumpets are a symphony. I picked up this 550 from The Netherlands last August and drove to Spa for the race, that euro to usd conversion was favorable.
