599 - Reverse (gear unavailable) | FerrariChat
Discussion in '612/599' started by Justin Hughes, Mar 29, 2021.
  1. Justin Hughes
    Justin Hughes Karting
    187
    Oxfordshire - UK
    Hughesie
    Hi all
    weird one today
    car recently serviced and driven less than 50 miles but just come out of two weeks storage on trickle charge
    all fine till trying to select rear - no warnings just displaying gear unavailable - all forward gears working fine - just unable to select reverse
    any thoughts or ideas ?
    hughesie
  2. marcmc8867
    marcmc8867 Formula 3
    Jul 27, 2004
    1,028
    NC
    Marc M.
    My 612 does this occasionally. I don’t yet know the reason but it always is solved by putting into first gear and then try and reverse again.
    Camp Freddie likes this.
  3. brogenville
    brogenville Formula 3
    2,257
    Robin
    Best guess is that one of the various permissives needed to select reverse isn't met. For example, the car needs to see brakes on, speed zero, clutch engaged etc. before it will allow reverse to be selected. I suppose you could use live data monitoring to see what's up.
    Mor and George Vosburgh like this.
  4. r0sco
    r0sco Karting
    114
    Melbourne
    Ross
    I had a similar problem with my 612. It didn’t happen every time and usually (but not always) when the engine and gearbox were cold. The techs at my dealer were unable to diagnose the cause but they (and I) believed it was a hydraulic issue. Over a couple of years they replaced F1 pump, accumulator, sensors, clutch, flywheel and thrust bearing, gearbox oil, battery, you name it, and each time it improved a little but it wasn’t fixed. Eventually they persuaded me that it was probably an internal gearbox problem, and when they stripped it down they found a damaged selector rod bushing and wear on other bushes. They replaced the damaged parts and also the synchronizer hubs and a bearing.
    The car has been perfect ever since.
    Good luck with your diagnosis.
    of2worlds and brogenville like this.
  5. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    Thanks all - worked fine after being left over night :)
    Will see if its an ongoing issue.
    Its done 500 miles on a new clutch so its not related to that I don't think :)
  6. tazandjan
    39,147
    She just wanted you to know she is female and likes attention.
  7. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    Gah, its back again !
  8. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    You say 'just serviced' what did that include?
  9. tazandjan
    39,147
    Reverse button?
  10. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    Annual Service - Oil and inspection
    Pads & Fluid - CCB F&R inc sensors etc
    Uprated fluid
    FR Lower ball joint & Hunter wheel Alignment
  11. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    I don't think so, its working, just not engaging reverse it seems.
  12. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    A lot of possibilities. Bad sensor (many can do it but if it thinks the shaft is turning it won't go into R), clutch dragging (not fully disengaged, again many causes), brake switch, .... the list is long. You need a a lot of time and/or a computer to solve this one.
  13. tazandjan
    39,147
    John- Affirmative, but most of those things will also prevent her from selecting first gear. Difference is first is selected with the paddles and reverse is selected with a push button, so something to do with that unique selection mode.
    Skidkid likes this.
  14. Tarooky
    Tarooky Rookie
    Dec 30, 2021
    1
    Tarek Mokhtar
    I got the exact same problem, just curious about the cost of fixing that internal gearbox problem, sounds expensive?
  15. r0sco
    r0sco Karting
    114
    Melbourne
    Ross
    I sold the car last year and gave the new owner all the service records, sorry I can’t remember the cost. I think it was less than $US8k for the gearbox rebuild. It is difficult to diagnose without stripping the gearbox down to inspect it. Good luck.
  16. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    A new Actuator box sorted my issues, been fine ever since, cost around £7k
  17. George Vosburgh
    George Vosburgh F1 Rookie
    How many miles Justin??
  18. George Vosburgh
    Ross, can you remember approximately how many miles you had on the car before the rebuild?
  19. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    56k (miles), now on 62k and like new :)
  20. George Vosburgh
    Thank you Justin, I'm always interested to hear what other cars with "high" mileage are doing. I think I'm going to bite the bullet and do the front shocks this fall, 45K+ miles.
  21. Justin Hughes
    187
    Oxfordshire - UK
    Hughesie
    I'm just midst replacing ALL of my Ball joints, Bushes, Flambloc's with Hills ones as well as braided hoses, Shocks look like they are still going strong (Famous last words) - so suspension should be good for another 5 years at least !!
  22. r0sco
    r0sco Karting
    114
    Melbourne
    Ross
    George, about 18k miles. I have no evidence for this, but I wonder if the car was driven hard in Sports mode before the gearbox was properly warm. It’s just a theory which might explain it. When I bought the car in 2010 it had about 11k miles, but I don’t have any specific details about the history.
    George Vosburgh likes this.
