612 clutch mechanism | FerrariChat
Discussion in '612/599' started by swiss612, May 19, 2016.
  1. swiss612
    swiss612 Karting
    May 10, 2016
    217
    Zurich
    Michel
    Hi all, The car that I just bought has a clutch sensor and "clutch mechanism" (this the word used in the Ferrari system) changed under guarantee in the first 5000 kmiles
    Clutch sensor I read about but clutch mechanism is something I did not see on the net for the 612, would you know which part it is? Was this part of the recall for the sensor?
    To me a clutch mechanism is the big spring that enables trust to be constantly applied on the disc and get torque, these things are normally changed with the clutch and don't go wrong...
    Anyway, let me know which part you think it is
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    You will need to ask that question to the person that performed the work.
  3. tazandjan
    38,120
    Clutch position sensor. There were quite a few changes to these and one recall in the 2005/2006 timeframe. The F1 612 uses the same clutch as the three pedal 612 (and 456/456M/550/575), except the throw-out bearing has different seals for the different fluids (F1 synthetic ATF, 3 pedal brake fluid). The clutch position sensor tells the F1 system clutch position for use with the hydraulic actuator for gear shifting and clutch actuation.
