77 308 -- stubborn headrest--any solutions? | FerrariChat
Discussion in 'Technical Q&A' started by greg328, Jan 12, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,179
    Austin, TX USA
    Greg
    I cannot get my headrest to move at all--either of them! The manual says they will raise, but mine aren't budging. (hand effort only--I haven't resorted to a crow-bar---yet!!)
    Anybody have any ideas? I guess I could squirt some WD-40 or somesuch down the rods.......
    Seems like it would be safer in the event of a collision to have that thing actually in back of my head, rather than down where my neck is.....
    Greg
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,544
    Toronto / SoCal
    Rob C.
    Those headrests can be a royal pain to move. Most of them have not moved since the car was new. WD-40 is a good idea provided you keep it off the leather and and some brute force comes in well too. Be careful because they may go loose all of a sudden and you don't want to punch yourself in the face by mistake.
  3. Chiaroman
    Chiaroman Formula 3
    1,665
    New Jersey
    I have a "78 308 and one headrest moves but the other does not.
    Let me know how successul you are in loosening them.
    Maybe a VERY small drop of high quality oil once in a while on the metal shaft will help?
    The smell of WD40 is horrific and would detract from the smell of the leather.
    Yours,
    Tom
  4. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,179
    Austin, TX USA
    Greg
    thanks Robert and Chiaroman. Makes sense about the WD-40 odor. I'll try a few drops of lubricating oil, see what happens....
    Greg
  5. thecarreaper
    thecarreaper F1 World Champ
    17,750
    Savannah
    on both of my 308's, when i finally got the damn headrests out i stuck a large shafted screwdriver in the holes and moved the metal retaining clips to allow some movement. i also used an artist paint brush and a SMALL amount of bearing grease on the shafts. there are detents that you are supposed to push in to release the holding clips, but i have yet to have these work properly. you can feel them in the leather a few inches down on the shafts.
  6. BigTex
    79,294
    Houston, Texas
    Bubba
    I wiggled mine side to side in lieu of yanking vertically to get them up.....
    Definately adjust them to the proper height......
  7. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,179
    Austin, TX USA
    Greg
    Thanks Michael and Tex, I'll try those ideas...
    Greg
  8. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    I had the same problem. Probably from all the leather oil applications over the years getting between the seat and headrest. I took a credit card and slid it between the two to free things up. then I just lifted up vertically and they came apart.
    Dan
  9. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    You can just drill off the rivets on the seat back to get in and fix it properly.
    If you want, you need not replace the rivets, just use screws with cup washers like on the doors.
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,019
    Groton, MA
    Verell Boaen
    My headrests didn't work at first, they seemed to be glued down by leather dye. Finally worked them loose.
    Also remember someone reporting that their headrest shafts had started rusting. This may well be what you're fighting. If so, then polish the rust off with fine rubbing compound, metal polish, or a gentle household cleaner like soft scrub or Bartender's Friend.
    Do not use WD40, the solvent in it attacks plastics. A little light machine oil like 3-in-1 s/b ok to get things off, however once things are apart I'd clean it all off.
    When you get them loose, I recommend a small amount of Radio Shack's Teflon Lube Gel. Very inert, no smell, doesn't attract dust & won't hurt the plastic.
    Alternatively, spray some silicone lube on a pad & wipe the shafts down with while it's still wet.
    BTW, Ferrari.uk has the plastic guides for the headrest shafts. If they ever run out, contact me, I've got a pair of NOS ones tucked away in case I ever need to make a mold.
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,679
    Cerritos, CA.
    Seem like this is the only way mine will pull up, I tried every way and this is the only thing that works without taking it apart.
  12. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Guys the simple way is just to remove the back panel and see what the problem is and then fix it. It only takes 10 minutes to remove the panel. Seems like you have taken more time trying to pull it up. Simple job , no brainer and even a caveman can do it.
  13. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,179
    Austin, TX USA
    Greg
    Wow, this is an old thread of mine coming back to life!
    The way I finally got mine loose--I removed the seats, put 'em in the driveway, put a foot on the seat cushion and just yanked on 'em. I was able to exert more force this way. They came loose, and I lubed them, so all's well..
    Greg
  14. BigTex
    79,294
    Houston, Texas
    Bubba
    I borrowed some silicone spray at a Harley Dealership and slapped it side to side a few times....I found the leather dressing over years had stuck it to the top of the seat.
    Didn't pull the seats but slid them to mid travel to get better leverage....
    They watched out the window from Parts Department and laughed.......
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,219
    Twin Cities
    Tim Keseluk
    Could a therapist?
  16. miketuason
    Feb 24, 2006
    15,679
    Cerritos, CA.
    What do you mean "the rapist"? :)
  17. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    I had the same problem w/my 308 2V...someone mentioned pushing something behind the seat..realized later I was getting my chain jerked, Never did move them...
    Now My 328 I have the same "stuck" headrests, I will try some silicone & the side to side motion. Makes me think Ferrari built them to spec exactly this way...stuck!
  18. BigTex
    79,294
    Houston, Texas
    Bubba
    It's the plastic siezing on the steel rod IMO.......there was still snow on the ground where I was having the issue..
    Also be careful of the plastic bushing breaking or pulling out!
    Beat it side to side gently, if you know what I mean.......it took a good tug once I had worked it a few times, then it yanked all the way out in my hands....slid it back in, to the desired height.....;)
  19. Steve King
    Feb 15, 2001
    4,367
    NY
    HAHAHA no to many brains
  20. miketuason
    Feb 24, 2006
    15,679
    Cerritos, CA.
    Is it the age or the design that makes this stubborn?
  21. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,179
    Austin, TX USA
    Greg
    Both, probably...
  22. Whiskeyman
    Whiskeyman Rookie
    Jan 28, 2007
    31
    West Chester, OH.
    Mike Calvert
    I have an 85 308 GTSi QV with only 7,128 miles on it. I have pulled the seats out and am refurbishing them with LEATHERIQUE products. I to would like to move the headrest up several inches for safety reasons. The best suggestion seemed to be, was to remove the back panel however this component of the seat seems to be riveted into place. I am reluctant to drill these rivets out. I'm sure, most all of us have willing invested more money in these cars than we wanted and I for one am reluctant to accidentally damage the seat. There is no mention in my 308 owners manual addressing adjusting these headrest. To play it safe I am going to let the headrest stay where they are.
