787 fire at Boston Logan | Page 17 | FerrariChat
Discussion in 'Aviation Chat' started by DMC, Jan 7, 2013.
  1. WilyB
    WilyB F1 Rookie
    4,272
    AZ
    #401 WilyB, Mar 22, 2013
    This is BOEING presenting the fire box to NTSB. We should do a caption contest... I love the facial expressions for the guys at the far end near the easel. :)
  2. jcurry
    24,084
    In the past
    Jim
    They've talked about adding airflow and purging the box to the outside atmosphere. Can't imagine it would be continuous, which means they have to have a system to turn on the purge and also dump values through the pressurized fuselage shell. Wonder if they plan on using nitrogen for the purge or just cabin air. Anyone know if flammability of Li batteries is affected by an inert atmosphere?
  3. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #403 Spasso, Mar 26, 2013
    It was my understanding that the fire located on the Boston fire was where oxygen was available, NOT inside the box where it was simply smoldering, albeit at a ridiculous temperature.
    To me pumping continuous air/oxygen through the box just enhances the issue. Might as well throw gas on a fire.
    NOW, if they bled the gasses from from the Nitrogen Gas Generation system used to purge the empty fuel tanks in flight it would make sense to provide constant pressure to the inside of the battery box. No oxy, no fire, unless you are dealing with magnesium.
  4. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    The fuselage of almost any airliner is constantly purging pressure to the outside during flight, No need for dedicated pumps, just some rerouting.
    Your point about cabin air is another sticky question. Adding cabin air to a potential fire hazard is bothersome. See my post above.
  5. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    The guy at the end with the lap top is thinking
    " if he rejects it, I just push the "esc" key here and he goes up in smoke with out a trace, we call NTSB and say your inspector never showed, we can keep that up till one passes it :)"
    The dude with the glasses, waving the pen is saying "not yet Bob, not yet"
  6. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
  7. docmirror
    docmirror Formula Junior
    May 6, 2004
    781
    Ft Worth TX
  8. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Might as well fly a DC-3 (and my brother used to fly them)
    How embarrassing....
  9. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    This plane is officially dead. No matter what they do this plane will never live up to the companies and airlines expectations. I imagine they will kill it and use what they have learnt to produce 797 RealWorldLiner.
    I can see them refunding contracts to keep the airlines on side and selling them their old 747's back, after a quick spit and pollish.
    Pete
  10. Tcar
    Tcar F1 Rookie
    That's just nonsense.
  11. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,693
    Washington State
    Brian
    I'm one of the biggest Boeing 787 critics, and even the above statement isn't true. The operators that have received and operated the 787 are reporting better than expected fuel burn rates (early delivery aircraft are nearly 4000kg overweight) on the later delivery aircraft over the 767 (I've seen figures as much as 21%).
    However, with a plane that seems to spend more time on the ground than the air due to electrical issues, any positives about the plane are immediately wiped out. Very much like Ferrari. It's a blast to drive, when it works.
  12. docmirror
    May 6, 2004
    781
    Ft Worth TX
  13. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,437
    FL
    All they need to do is build only the 737 and 777 passenger and cargo versions and they'll be profitable. If it ain't broke, don't fix it. ;)
  14. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    That is my point, and now it can only be used for 2 hour flights (I think) surely making them ineffective?
    Pete
  15. jcurry
    24,084
    In the past
    Jim
    It means they must be less than 120 minutes flight time on one engine from a suitable airport (i.e. one at which they can land). They can still fly 8 or 9 hr flights as long as they meet that criteria.
  16. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    Incorrect. That certification (if its is applied which at this point is pure speculation), means it can not be more than 2 hours flying distance from a suitable airport.
  17. BMW.SauberF1Team
    Dec 4, 2004
    14,437
    FL
    Right, but how many routes would that effect? Trans-pacific still okay? Not sure of an airport every 2 hours away with 1 engine that is "suitable," but you never know. All the small islands around there may be able to land it.
  18. docmirror
    May 6, 2004
    781
    Ft Worth TX
    #418 docmirror, Mar 27, 2013
  19. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Is the battery really THAT SMALL? (or is this just one cell?)
    I was picturing something MUCH larger than that in my mind.
  20. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Oh, I missunderstood. That changes everything I said on my last post.
    Pete
  21. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    The 787 is no Ferrari and right now it isn't the 787 that was designed. Yes, it has a problem and that problem is being fixed and will have permanent solution to the problem. I can think of a lot of programs that had birthing issues: the 299 (B-17), 314 (Clipper),345 (B-29), 367 (Stratocruiser), B-47, B-52, 707, Lockheed Electra, DC-8, DC-10, 747, and many others. This entire concept has great potential but a lousy business plan has hobbled it. Boeing will get it fixed and they will have a great airplane. Any outfit that has the guts to push into the next stages of technology will face some challenges and missteps and Boeing has done this many times in the past AND they always succeeded.
  22. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Not much bigger than a truck battery.
  23. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    IN COMPOSITE BY UNITED STATES ENGINEERING AND ESTABLISHED QUALIFIED SKILLED LABOR (US and Japan)
    Both of those airplanes would be world beaters.
  24. Tcar
    Tcar F1 Rookie
    YES!
  25. leexj
    leexj Rookie
    Aug 1, 2012
    44
    Placerville, CA.
    Lee
    I pity the people on the plane when this thing has to be replaced in a third world country where A&P standards are a little lower and by a little I mean non-existent.
    Do you have to torque each of those bolts, too?
