'79 308 restoration | Page 13 | FerrariChat
'79 308 restoration
Discussion in '308/328' started by Newman, Dec 30, 2003.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    Well, for starters its my job and since im always doing this sort of stuff its not that hard. Secondly I take pictures, very specific ones that get me out of trouble from time to time. Also I measure every bolt, stud, washer, record head diameter, length, bolt size, colour, location and any special markings such as "lobo" on a bolt head. This way they get plated the colour they were and go back where they belong. I was surprised on the engine to gearbox mounting studs, there are 4 different types so I recorded the location of the specific sizes. Prior to plating I record the number of fasteners like just how many bolts, how many studs and washers but not specifically the sizes. This way I know if anything is lost in the plating process and I can narrow it down and bust some balls. I refer back to the charts when I come to a specific part I want to install, look it up and see how many of what and what colour they were, most stuff I can identfy on looks alone but I still need the charts or it would take me a much longer time.
  2. opus10583
    opus10583 Formula 3
    Dec 3, 2003
    1,779
    Westchester, NY
    Mark
    What's that block in the bottom picture of post 290?
    Great Thread! Thanks!
  3. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    2001 cobra mustang. Rebuilding them keeps me busy and takes time away from the 308.
  4. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    #304 Newman, Jan 17, 2007
    Ignore the fitipaldi wheel, its getting replaced when I get around to it. The tanks are in, the cables, hoses, etc, still have to install the cross-over pipes with new hose connectors then the engine can go back in. The dash, heater and air conditioning box is in. The pedals have new rubber pads, the gas pedal is powder coated (yes its incorrect but durable), shifter and e-brake lever are all there as is the headliner and lamp. Ill concentrate on the engine bay for now then work on the brakes and get new tires on the QV rims so I can get it down on the ground for the first time since 04 and have it actually look like a car again.
  5. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    Cool stuff, man. :)
  6. mike308gts
    mike308gts Karting
    Aug 28, 2006
    97
    Washington NJ
    Michael
    Damm!!!
    The man has guts!!!
  7. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Thanks Guys and Gus, where are the pics of the new 328?
  8. opus10583
    opus10583 Formula 3
    Dec 3, 2003
    1,779
    Westchester, NY
    Mark
    Absolutely fantastic!
    Why the red paint on the coils in post 304?
  9. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    inspection marks, Ill pass on all the yellow dabs all over the suspension bolts though. Im not going for concours correct either, more to the over-restored catagory and tasteful improvements like less weight and the euro look on a North american spec car with a little more power. The problem im faced with is I wont keep the car long term as my wants have changed so do I sell it right away once finished so its not even dusty and get the most dollar I can, or drive it and take less down the road. Im not sure yet.
  10. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    The trick I use with the yellow dab, on any car, is: A yellow dab of paint tells ME that I have torqued that bolt/nut/etc. If I find an unpainted fastner I have found a potential accident.
    rick '79 308GTB, other stuff
  11. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Yes thats the reason for it on the assembly line as well. I double check everything so the paint isnt needed in this case, plus i just dont like the look of it after everything has been plated. Personal preference thats all.
  12. opus10583
    opus10583 Formula 3
    Dec 3, 2003
    1,779
    Westchester, NY
    Mark
    Forgive my obtusness, but I don't get the marking on the springs...
    "Coils? ...Check." ?
  13. Steve Magnusson
    26,783
    The color marking is used to indicate the measured load applied to the spring in order to compress it to its working length. It's difficult to make all the springs exactly the same so they sort them into sub-groups and use the color-coding to easily keep track of "pairs" on the assembly line -- see page F4 in the 308GT4 WSM.
  14. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    you are forgiven, thanks Steve.
  15. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
  16. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    Just saw this thread for the first time. Awesome thread!!! Thanks so much for sharing all this with us.
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Steve, is there anything you don't know? ;) Man, how do you remember all this trivia?? You are the only guy I know who has probably memorized the owner's manual and service manual for all the previous generation of Ferraris!
    Birdman
  18. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Hey no problem, a large portion of the pics got lost in the f-chat melt down a while back so some of the stuff is gone and the order isnt great but you all get the idea. Ive learned a lot about the brand from this one car so for me its worth every penny as well as my time.
  19. Jdubbya
    Jdubbya The $10 Trillion Man
    43,167
    PNW
    Paul,
    I've got to get going on getting mine back together or you are going to beat me!
    Keep up the great work and thanks for documentiing it all here for the rest of us to see!
  20. cessnav8or
    cessnav8or Formula 3
    May 28, 2004
    2,257
    Louisville, KY
    Aaron
    #320 cessnav8or, Jan 19, 2007
  21. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Looking good Newman.
    It's funny to start from the beginning & see posts I don't remember writing.
  22. KershIrl
    KershIrl Karting
    Aug 10, 2004
    92
    Dublin, Ireland
    Stephen
    Just read this entire thread.
    Serious amount of work, absolutely brilliant to read, fair play.
    Its lovely in yellow!
  23. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    Congrats on progress so far. Great color. I'm going to start an anything but red movement. Have you found hose for the blower to heater connection yet? If so, where?
    Tom
  24. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    I didnt need to replace the hoses for the blowers and Im glad. They cleaned up very well, had no holes or anything and im not sure where I would get an exact replacement.
    Thanks for all the positive feed back everyone, as for the fuse blocks mine are mint so I decided to retain the factory ones as good as birdmans upgrade would be.
  25. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    If it were me, I would at least drive it a little (1,000 miles or so) to enjoy the fruits of my labor and also to make sure all the bugs are worked. I don't think thoses few miles after such an extensive rebuild would reduce the selling price any.
