812 VS Rumors | Page 276 | FerrariChat
812 VS Rumors
Discussion in 'F12/812' started by Frenzisko, Feb 10, 2018.
  1. Maximus1977
    Maximus1977 Formula Junior
    Feb 13, 2016
    324
    Absolutely agree.
    It's a ferrari Road car design. So it has to have that Ferrari DNA in- and outside. Unless indeed it would be more like a (barf) Senna. A car that manages to be even uglier in real life than pictures.
    So it's a form follows function for Ferrari.; which still means a hefty degree of elegance. It's only less elegant than other models.
    Perfect to my liking!
    350MH83, ingegnere and Boots like this.
  2. Elisesko
    Elisesko Karting
    210
    Making up for any power loss due to the GPF isn't something that I've seen advertised by Ferrari in any of the applicable models where direct comparison to pre-gpf is possible. For other manufacturers I've seen anything up to 10+% loss. Unfortunately, some of the advertised power increase here was limited by having simply to get back to base 812SF power.
    crinoid likes this.
  3. Maximus1977
    Feb 13, 2016
    324
    Meaning without GPF we would be looking at a 900hp powerplant!
    Who's willing to get rid of the GPF and do a software tune.....!?
    crinoid likes this.
  4. ingegnere
    ingegnere F1 Veteran
    5,567
    Montreal
    Pretty sure Cosworth doesn’t offer a 15-year powertrain (extended) warranty, though.
    REALZEUS and crinoid like this.
  5. renzone
    renzone Rookie
    Jan 23, 2018
    48
    lorenzo rossi
    Aston Martin has severe financial problems. Very likely the Valkyrie will fail as a project. At McLaren they also have serious problems of the same kind. Ferrari plans and designs for the long term with efficiency and method.
    Alvega and dpw98 like this.
  6. ferrarifanatic25
    ferrarifanatic25 Formula Junior
    Apr 9, 2009
    889
    OC
    Thank you for finally bringing this up^^ I was getting caught up on this thread this morning and couldn’t believe no one had mentioned the GPF.
    Comparing the VS to the standard SF is not an apples to apples comparison. Assuming a conservative 5% power loss to GPF, we’re looking at 40 hp. Add the additional 30hp increase and we’re looking at a total of 70hp. They already had to beef up the engine for the GTS just to match the same output of the SF. The fact that we are getting another 30hp out in the VS is a miracle.
    For those of you disappointed in the power increase, you can go complain to the EU.
  7. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,595
    Austin TX
    At present the "Valkyrie" and its Cosworth V12 are not released, years late and getting later, Cosworth has never made a V12 engine before this and the last road car a Cosworth engine (really just heads, not the entire engine, used MB block) was used in was more than 35 years ago (MB 190E). Cosworth's main claim has been F1 engines, which do not require the durability of a road car and even then, it's been about 10 years since Cosworth made an F1 engine. Yes I realize T.50 will also use a Cosworth V12 (completely different size, much smaller block) and Gordon's cars are definitely built like race cars including huge maintenance costs just like a race car.
    So, until the Valkyrie is released to "road car" customers and has some history, especially its durability (which cannot be known until in-use by customers and then customer's who actually use it) it is completely irrelevant and is 100% invalid for comparison. Yes, I understand Cosworth has done durability bench tests, but the block is to be part of the frame of the car and that's not been as tested, the violent shaking the block will endure, etc (sort of like the F50 construction).
    Another thought is Audi/Lamborghini, they clean sheet designed the V12 for the Aventador and its maximum power is similar to Ferrari's (little less). There is probably good reason for this as those engines must have durability.
    Lastly, the Cosworth V12 "1000hp" claim was from 2017/2018, pre-GPF, and EU noise regulations, will it actually remain with the same specs whenever it is realized as a road going car....
  8. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,595
    Austin TX
    No, the GPFs remove about 20-25HP, to go from 819HP (830PS) to 900HP (912PS) would not be possible.
    Without GPF, the 812VS would likely be about 855PS (843HP) (that's not to say removing GPF and Catalysts will not result in even more power, it would, but even then 900HP is unlikely).
    And a good deal of the extra power in the 812VS is due to the substantial increase in rev limit to 9500 from 8900.
  9. Jonathan19
    Jonathan19 Formula 3
    Sep 13, 2017
    1,419
    France
    Jonathan
  10. F140C
    F140C Formula 3
    Nov 25, 2016
    1,575
    Piedmont
    Marco
    I'm sure Novitec or Fabspeed will do something about sound and power (not 900CV, but more than stock).
  11. Boots
    Boots Formula 3
    Jan 17, 2020
    1,663
    Canada
    Jake
    OneD, Caeruleus11 and JTSE30 like this.
  12. TAM340R
    TAM340R Formula Junior
    Jul 26, 2015
    268
    would you pls post the link of the mentioned threads?
    I did not find them
    or is this the one you wrote about?
    The new Ferrari Versione Speciale
    thanks
    Tam
  13. SECRET
    SECRET Formula 3
    1,045
    Maranello, Italy
    Ferrari Tifosi
    Yeah agreed. I tried to play around with it too: https://www.ferrarichat.com/forum/posts/147857457/
  14. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,518
    Bournemouth, UK
    2019 actually and they said that it passes Euro 6, without the need for a PPF (GPF), as it uses multipoint injection instead of direct. But I understand all the points you are making and the Valkyrie has to prove these claims in the real world.
    ingegnere likes this.
  15. dcmetro
    dcmetro F1 Veteran
    Nov 27, 2007
    9,053
    Paris , France
    Olivier
  16. Gianfranco341
    Gianfranco341 Karting
    Sep 12, 2017
    248
    Gianfranco
    I don’t agree at all !
  17. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,732
    We will probably never know, because this car is unfortunately not intended to be driven.
    The reason is simple, no owner has the piloting to operate this kind of machine other than straight line runs.
  18. GrigioFox
    GrigioFox Rookie
    Dec 13, 2016
    7
    It is a really beautiful car. It will be undoubtedly be an amazing experience on the road. Ferrari will make 1,500 of them.
    Sadly, these 1,500 cars will sit in collections and storage around the world and rarely be seen. The vast majority of them will never do more than 200km a year - if that.
    Meanwhile the numerous genuine enthusiasts who regularly drive their cars on the road are prohibited from the opportunity of buying one: It is difficult to believe that such customers are actually valued by Ferrari.
  19. Lukeylikey
    Lukeylikey F1 Rookie
    3,700
    Not what’ll be happening with mine....
    I know two others with confirmed allocations. Theirs won’t sit either.
    I get the theory but it doesn’t always follow.
  20. GrigioFox
    GrigioFox Rookie
    Dec 13, 2016
    7
    That's fair and you are very lucky. But I would bet that the bulk of those allocated a car haven't even heard of FerrariChat!
  21. Maximus1977
    Feb 13, 2016
    324
    Same with mine and with my buddies car. We will drive and track these babies!
    Again, hence the preverence to racing drivers....
    stavura, TSOYBELIS, Dubaicity and 3 others like this.
  22. Maximus1977
    Feb 13, 2016
    324
    A lot of passionate and active collectors actually have. They just don’t post, but they are reading
  23. roma1280
    roma1280 F1 Rookie
    4,848
    Palm Beach, Roma
    I promise I am going to put 100,000 km on mine if I can. I did over 50,000 km in my F12 and have 93,000 km on my 575. To me the car is going to be worth zero after I write the check and I am going to drive it until the wheels fall off. That includes driving it as fast as I possibly can on track (or as fast as my mediocre driving skills will allow).
    Nicolas21, stavura, Shack and 20 others like this.
  24. 456-boy
    456-boy Formula 3
    Jun 23, 2005
    2,058
    France
    Victor
    TMO98000 and perrinnation like this.
