812 VS Rumors | Page 56 | FerrariChat
812 VS Rumors
Discussion in 'F12/812' started by Frenzisko, Feb 10, 2018.
  1. mepassione
    mepassione Formula Junior
    Aug 17, 2019
    944
    Passione
    Wikipedia mentions the 488 as being F142M and it didnt prevent the pista from being produced. In the case case of thev488 the F142VS-M was a downsized displacement with turbo... could it be then that the 812VS will also be V12 turbo with smaller displacement ? From the sound of the test mule as pointed out previously that could be the case. And that engine could be the base for future v12 turbo hybrids used in the car that may well sit above the SF90. Will the 812VS really be therefore na v12? Unsure
  2. dcmetro
    dcmetro F1 Veteran
    Nov 27, 2007
    9,052
    Paris , France
    Olivier
    Changing from NA to Forced induction means reegineering most of the car, in this case I believe Ferrari would have waited for the 812 replacement
    At least until now all the VS version use the same engine as the basis version, in an upgraded version, but the type, type of induction, displacement remains the same
    JagShergill and of2worlds like this.
  3. ajr550
    ajr550 Formula Junior
    Apr 6, 2014
    979
    UK and Caribbean
    Andrew Roberts
    Hi Olivier,
    Good to have you back and posting.
    I have always assumed 812VS will follow normal pattern and be a lightened 812 with more aggressive bodywork and a slightly reworked chassis and engine.
    It is a big want for me so also hoping it will not be Limited Edition.
    There have, however, been quite a lot of hints that engine may get some "help".I hope not but normal rules don't seem to apply any more !!
  4. mepassione
    Aug 17, 2019
    944
    Passione
    Bonjour Olivier,
    In a context where the 812 is already labelled 812VS-M so modificata tdf, lighter than the F12, and with the new GPF added which takes out power, do you think it’s realistic to expect a traditional VS of the 812 with more power ( meaning probably close to 900hp before gpf) and materially less weight?
    Merci d’avance.
  5. ppg70
    ppg70 Formula Junior
    Aug 22, 2017
    930
    As my previous posts N/A with special help
  6. ppg70
    Aug 22, 2017
    930
    R
  7. ppg70
    Aug 22, 2017
    930
    +1
  8. ppg70
    Aug 22, 2017
    930
  9. BG23
    BG23 Formula Junior
    Jun 16, 2015
    446
    Australia
    Mild Kers?
  10. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    I think test mules require an electrical triangle symbol (shown on the exterior) if KERS/battery assist, maybe a supercharger
  11. Albert-LP
    Albert-LP F1 Veteran
    8,187
    around Modena, Italy
    Alberto Mantovani
    It can have a turbo and be NA… ;)
    Turbo doesn't mean always Turbo Charger ;)
    ciao
    of2worlds, ferrarifanatic25 and 9nb like this.
  12. Albert-LP
    8,187
    Alberto Mantovani
    here there is (almost) everything
    ciao
    PS
    I would say very close to 900...
  13. dcmetro
    dcmetro F1 Veteran
    Nov 27, 2007
    9,052
    Paris , France
    Olivier
    Hello Mepassione,
    I'm far for being the best expert to answer, but I do believe that's quite possible,900hp is maybe a little too much, If you consider the ration of the Gto Vs GTB and Tdf Vs F12, I would say around 850
    Cheers,
  14. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,651
    So an e-turbo. Makes sense since it won’t impact sound however they’ll have to integrate a 48V system.
  15. Albert-LP
    8,187
    Alberto Mantovani
    I don't think that a 48 V system can add a lot of power… 350 A are 23 HP only...
    I would go in another direction
    ciao
    of2worlds likes this.
  16. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,651
    48V to drive the e-turbo compressor only.
  17. mepassione
    Aug 17, 2019
    944
    Passione
    So we are saying here the 812SF is the last non assisted na v12 and as far as sound is concerned probably the last of the great sounding V12 for pre GPF 812 since the VS like the GTS will have GPF which as we all know doesn’t produce as good a sound
    Is therefore the pre gpf 812 the one that will mark the end of an era as suggested by both Jethro Bovington and Chris Harris? Should we appreciate that car and the F12 more ?
    F12JAJ, JTSE30 and Maloja like this.
  18. Albert-LP
    8,187
    Alberto Mantovani
    N/A = no compressor
    And with 23 HP you can't move a compressor that has to feed a 6.5 liter engine that revs at 9+ k rpm
    ciao
    Doug23 likes this.
  19. mepassione
    Aug 17, 2019
    944
    Passione
    E turbo technology that can help ferrari downsize the engine for further weight reduction. Either way if that’s the case this is the base for the future 812 replacement which will be turbo/hybrid with gpf
  20. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,651
    Perhaps use the e-turbo as a kind of torque fill at lower RPM and then turn off at higher rpm?
  21. Doug23
    Doug23 Karting
    Jun 23, 2017
    193
    Italy
    Turbocompound?
    Tapatalk @bah-L09
  22. mepassione
    Aug 17, 2019
    944
    Passione
    For info i was told today Ferrari aren’t taking more orders on the 812SF and are focusing on the GTS and maybe who knows the VS
  23. ajr550
    Apr 6, 2014
    979
    UK and Caribbean
    Andrew Roberts
    They always do this!
    Had a plan.
    Perfect garage was 812 VS plus Pista.
    Now I need to keep the Superfast as well if I get a VS allocation.
    Probably wrong thread but do Monza being produced now have GPF ?
  24. Lagunae92
    Lagunae92 F1 Rookie
    3,101
    SoCal
    I know....This is hot on my list. Curious to see what it ends up being. Things are kind of sounding good for the life of the 812 without GPF.
  25. mepassione
    Aug 17, 2019
    944
    Passione
    Everything seems to be Pointing in that direction at least. Could that mean higher future value and desirability? Let’s see. I have a feeling if that’s the case F12 will also be more appreciated sooner than we think
    Lagunae92 likes this.
