A/C Bleeding | FerrariChat
A/C Bleeding
Discussion in 'Technical Q&A' started by MarkG, Mar 25, 2004.
  1. MarkG
    MarkG Formula Junior
    Nov 3, 2003
    369
    Colorado Springs
    Mark
    How can I - or even can I - safely bleed the freon out of my A/C; going to remove it completly for now to do timing cover bearings and radiator rebuild.
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Mark, if you are talking about your 82 308, you can just move the compressor out of the way.
    But if you feel the need to remove it, stop by any licensed A/C place and let them recover the freon before you start the job.
  3. BigTex
    79,368
    Houston, Texas
    Bubba
    It takes a special pump to reclaim it. As mentioned, any licensed repair shop has them.
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    MarkG,
    As recommended, go to an A/C shop & have them remove it. They'll give you credit for the removed FR12 which you can then use when you have the system refilled. The system holds a couple of pounds of FR12 which is going for about $70/lb these days!
