A few 360 Techincal problems... | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Scott_360M_F1, Oct 29, 2009.
  1. Uomo360F1
    Uomo360F1 Formula Junior
    Aug 24, 2007
    488
    Nobody has mentioned de factory recall regarding the ABS/ASR modules.
    AIR BAG: Electronic Control Unit
    BRAKES: Anti lock braking system ASR traction control system electronic control unit is affected by an error in production by the supplier.
    Check with an authorized dealer before digging for your wallet.
  2. SonomaRik
    SonomaRik F1 Veteran
    #27 SonomaRik, Nov 2, 2009
    Ray: I believe there are a couple steps in there about charging up the ECUs carefully and then, letting the ECUs mange the system before even driving off.
    IIRC, turn key to "ON" position, let sit for >30 seconds, then turn on car, let run @ idle for a few min....many in fact, THEN decide to drive off when the ECUs have recalibrated....BUT, as Rifledriver states, people who know better should dispense advice and I am going into that description based on recalling severall threads....many cobwebs in this brain.
    but, I do believe there are steps to take after an ECU has been powered down.
  3. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Thanks to all for the info. Always something new to learn about these cars.
  4. Skidkid
    Skidkid F1 Veteran
    9,689
    Campbell, CA
    John Zornes
    Correct but I too would have to look this up
