355 - ABS Pump Sticking Out? | FerrariChat
355 ABS Pump Sticking Out?
Discussion in '348/355' started by cvy612hgtc, Oct 5, 2019.
  1. cvy612hgtc
    cvy612hgtc Rookie
    Mar 17, 2015
    21
    HONG KONG
    So I had a locked ABS Hydraulic control unit (part # 70000768). Took car to specialist indie and got part installed and new brake fluid. Car drives great and error codes all gone.
    But then I noticed one of the rectangular carpeted covers under front hood was off. When I tried to put it back on it wasn’t possible as the black circular part from the ABS pump was sticking out (believe it is part # 148977 - last picture). Attached pictures explain it better than I can. What’s going on?! o_O Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login [/ATTACH] Image Unavailable, Please Login
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    308 GTB likes this.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    btw I have seen in other cars that switch accumulators, they rotate the pump for clearance, not sure whats involved with the 3xx cars in doing that.
    typo above post..
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    In a 355, you cannot rotate the pump unless you choose to not mount it at all. You have to find the correct accumulator bomb.
  5. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    I think your carpet has sunk, mine did. Right were the two parts join. Usually due to a little weight on it pushes the carpet down.
  6. ClydeM
    ClydeM F1 World Champ
    11,880
    Wayne, NJ
    Clyde E. McMurdy
    Qavion likes this.
  7. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    So for anyone with the above problem who are using the standard bulb that came with the car. If over time the boot carpet sinks, the same thing happens as above.
    So just for future reference, here's a couple of pictures of what can happen.
