Mondial T I note in the workshop manual that a fuse should be inserted in block 166 to earth the system to allow the fault codes to be displayed. All well and good, but my picture shows a left hand drive car and not a right hand drive car like mine. So i am not sure which one it is. Oh easy I hear you say check for the one missing a fuse, well there is a fuse in each !!! and 1 at each end has blown,!!!!! Could anyone tell me the make / number of the relay to which the test fuse holder is attached or even the colour of the wires. Thanks
Is your ABS not working? If the pump of the ABS will not work you also have no servobrake. If fuses are broken first replace them . Maybe it will work then. The fuses for ABS are 3 in a row on lefthand cars under the plastik panel on the right side . I believe it will the same on righthand driven cars. Its a Teves Mark 2 unit and you can find a thread with the error codes . Sorry dont know to put a link to it but its callde ABS error codes.
