Best way to upgrade 328 AC to blow colder?
WELL, HECK- THE THREAD IS STILL HERE- WHAT HAVE YOU DONE SO FAR TO CHECK AC SYSTEM OUT? pReSSURES? what kind of gas is in there?Last time it was checked/serviced? We can go from here, if you want to. Only thing- may be hard to do ac in cool time of year.
So I have made the decision that I want to stay cold in my 328 in the summers of Florida. i like driving with the top off which makes for quite the challenge of staying cool. Having done my home work I have decided that a fully electric system will do the job. i started to look at all the benefits and figured I might as well be the first one to do this. I have looked every where and have NOT found another 328 who has turned the inside of their car into Antarctica. I will be installing the 12V DC HB075Z12 Compressor with controller A/C Car Hot-Rod Solar 2890BTUs R134aill NOT the 12V DC JFSB116Z12 Compressor with controller A/C Car Hot-Rod Solar 6120btu R134a system at a cost of $599. Yea I know a bit over priced but in order to make sure the invert-er matches perfectly to the compressor needs I paid a little more for the package. The reasoning behind using the smaller btu out put is because of amp draw being 26 amps vs 55 amps. I figured it is only a small cabin and why draw what you do not need. I am hoping that 2890 btu will do the job. Well I will order it tomorrow and start the romoval of the old York compressor which I no longer need today.
