Adding CarPlay to my 812 superfast | FerrariChat
Discussion in 'F12/812' started by mnl, Oct 18, 2024.
  1. mnl
    mnl Rookie
    Jul 12, 2023
    31
    I got my 812 just over a year ago, the spec is great but since I got it there were two things that I wished i could change: it's got the regular shields on the sides, i wish they were painted since i think they're much better proportions for the size of the car, and i wished that the car had carplay… the day i got it i asked the dealer about installing carplay in the car and they said it couldnt be done. since then i've been looking online to try to figure out a solution, the main thing i've been following is this thread on the FF/lusso forum: https://www.ferrarichat.com/forum/threads/can-apple-carplay-be-added-to-a-cpo-gtc4lusso-v12.605977
    It seemed promising but there were lots of unanswered questions i couldn't really find anywhere, but after a ton of going back and forth i decided to just go for it and buy the module. Well I've just finished the install and it seems to be working great, exactly what I've been looking for this whole time. So i figured in case anyone else is thinking about doing this i'll share the whole process here since that was the main thing that was scaring me away and i couldnt find any answers anywhere online.
    tldr: 7 star screws, 1 bolt, can probably be DIY'd in an hour or so [especially if you're not a big person]…i made a few mistakes so it took me a couple of hours
    Comes with the carplay unit and a couple of cables and antennas. You'll need the cables [obviously] but you can ignore the antennas. First question, where does this go? I imagine this is different for each model, but on the 812 superfast the head unit is installed behind the seats under the luggage shelf.
    So first step is to remove the separator that has your car's spec on it, pretty self explanatory. The easiest bolt to undo is at the top of the shelf under a little door, you can just pull open the door and then undo that bolt. It has some lip attached to it, and then once you remove the bolt and the plastic box, make sure to also take the other end of where the bolt attaches to, it'll just be loose under the box.
    Then you'll pull on the two black tabs on the floor closer to the middle of the car. That reveals three star screws you need to remove.
    Then came my mistake, i was dumb and spent quite a while fighting the shelf trying to remove it, but what you need to do is undo the leather belts, and then you'll find four more star screws that you need to undo. One under each strap. The two straps closer to the seats will stay attached to the shelf, the other two have a little square protector you can just push back to get to the screws, then the whole strap will come away from the shelf.
    Once you take those 4 screws out you can just take the whole shelf out! Trunk side will be fully free, the other side just has a couple clips that come apart fairly easily.
    Bonus photo of the shelf on top of the little M roadster kept my shelf safe while I continued working on the car…
    Once you removed the shelf you'll see the head unit right there, you just need to undo the big cable on the far right, then the cable right next to it. Plug in the cables into the new cables that came in the box, then plug the cables into the head unit and the carplay unit.
    My next mistake was that i got too excited after i put it all together and completely forgot to take photos of it all assembled ‍♂️ However it's pretty self explanatory, you can put the carplay unit right above the head unit. It's a pretty great fit, tho i added a command strip just to make sure it was super snug and wouldn't rattle. Then just reverse the process to put it back together!
    One last note is the USB cable that comes with it. Not really necessary, it's only used for updates. However to avoid undoing the whole thing again i did connect the cable to the carplay unit and routed it to end up right under the plastic box, so if there is ever an update I can just undo one bolt to get to the cable and i'll be able to update the unit.
    And there we go, it works! Didn't even need to unplug the battery from the car or anything. I've never really done much work on the interior of cars before this [just undoing a single trim around my mirror to connect a dash cam in my GT4] so i think it's totally doable by anyone if you have the right screwdriver and wrench. Only caveat is as with any car work, maybe it's a bit more complicated if you're a bigger person. I'm pretty small so i just sat in the trunk of the car and did all the work pretty comfortably there.
    All in all I wish i'd done this a year ago when i bought the car it's 100% reversible and really easy to do. I'm glad i decided to try it out myself vs paying someone else to do it!
    I did a short test drive and there's only two small things I noticed in use. The first doesn't really matter, but when adjusting the volume, you can't see what the actual volume level is at while carplay is active. No big deal.
    The second is that i got used to using the control on the right side of the steering wheel to change songs, on carplay it now moves the UI selector along [as it should] however clicking the button in does not seem to do anything, so while you can move around the UI, to select anything you'll need to use the main control in the dash, not the control on the back of the steering wheel… minor thing that i think may be possible to address with an update.
    Not linking to the actual product since i'm not sure if it's allowed, but easy to find. And just to be clear, i'm not related to the sellers at all, i just bought it last week and decided to share the entire process since i couldn't find much info about it online! Happy to answer any questions anyone has!
  2. nguyennhatquang
    nguyennhatquang Karting
    Feb 13, 2016
    206
    Hanoi
    can you share a video how to enter the CarPlay menu? does it look like Factory Original ?
  3. mnl
    mnl Rookie
    Jul 12, 2023
    31
    i’m literally just heading out to the airport can share a video next week when i’m back!
    i’ve never used the original factory version, but it’s not quite 100% going to be the same since this is basically switching between the car’s system and carplay. you move from one to the other by holding down on the back button for a few seconds. however once it’s showing carplay (other than being unable to select with the steering wheel control) i don’t think it’s much different from the original since it’s just carplay, not much that can be different at that stage
  4. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    thank you so much,
    So I have another question.. when you play music via your CarPlay, how the original system get it ?
    via Aux in or what mode you select it to ?
  5. mnl
    mnl Rookie
    Jul 12, 2023
    31
    music works the same way that it did before carplay. so through bluetooth directly into the car. so sound goes to the car, then carplay is just the interface to manage the phone (tho if you go back to the car’s built in system you can still do the same stuff from before like look at now playing or skip songs etc) i can make sure to include that in the video so you can see it once i’m back!
  6. mnl
    mnl Rookie
    Jul 12, 2023
    31
    @nguyennhatquang ok here’s a quick video, hopefully it answers your questions. there’s a setting to either connect to carplay automatically or not when the car is turned on, i have that on so you can see it jump right into carplay. otherwise it stays on the ferrari UI instead. let me know if anything is unclear!
    can’t figure out how to put the video directly in here (is it allowed?) but here’s a link: https://imgur.com/a/B3cBV4p
  7. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    Thank you so much, seem like it work like original..so how is the sound quality ? is it sound good also compare with original ?
  8. mnl
    mnl Rookie
    Jul 12, 2023
    31
    yea sound goes through bluetooth directly to the original system, not carplay, so it’s exactly the same
  9. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    so we need to pair the Carplay module with the NIT system via Bluetooth? Or when you pair your Phone it automatically ?
    Because my F12 the NIT got broken, and replace it is too expensive and worthless
    I just wonder this carplay system can work without the Becker NIT unit
  10. mnl
    mnl Rookie
    Jul 12, 2023
    31
    not sure how it works on the F12 my understanding is that it’s a little different for each model. for the F8 and 812 you pair the phone to the car for sound, then carplay is just for display. so for the 812 you’d still need the working NIT i think, but i’m not sure how that works on the F12, you can try messaging marco the creator (phone is on their website) and see what they say
  11. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    thank youo so much for your help, so does the Joy Stick in the menu can control the CarPlay and how u Get into it in Ferrari Screen.
    and how you adjust the volume small or louder ?
    and does the steering wheel button on the back work ?
    thank you
  12. mnl
    mnl Rookie
    Jul 12, 2023
    31
    yea if you watch the video you can see it all in action. the joystick controls everything, and the scroll wheel on the back of the steering can also move the selection (it just can’t confirm the selection for some reason) tho the one in the F12 looks a bit different so not 100% sure it will work exactly the same. pressing and holding the back button switches between ferrari and carplay. the volume is managed the same way as usual, behind the left side of the steering or on the volume knob in the dash
    nguyennhatquang likes this.
  13. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    @mnl : so I have one more question, how many phone this CarPlay can Pair,
    example if I pair my phone on the car, can my wife pair her phone also, so we don't need to delete each phone when we swap driver ?
  14. mnl
    mnl Rookie
    Jul 12, 2023
    31
    don’t know what the limit is but you should be able to pair more than one phone the same way you can with the car itself
  15. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    So before I buy this unit for my 812gts I wanted pictures or video of where the head unit is on the GTS and how to access it, I was coming up with zero help so decided to do a little bit of my own investigating today.
    I found its very simple to get to the head unit, the stereo amp and what looks like the ABS unit.
    Open the roof part way, you want the rear cover fully open but the actual roof closed, see picture.
    Inside where the roof would store you will find a flock covered plastic cover held in place with 9 x 10mm bolts, undo the bolts and remove the plastic cover, you will need to coax it past the cables for the roof, all the components are now visible.
    I will go ahead and order the Apple car play/ Android auto unit and follow your wiring instructions.
    350MH83, nguyennhatquang and mnl like this.
  16. mnl
    mnl Rookie
    Jul 12, 2023
    31
    oh nice, looks like it’s even easier in the GTS! let me know how it goes once it arrives, should be really straightforward now that you got that far in advance
  17. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    Are you happy with your carplay unit, any major downsides?
    I like to use the analog type speedo in the right display, is this still viable when using car play or do you need many button pushes to answer calls etc?
  18. mnl
    mnl Rookie
    Jul 12, 2023
    31
    yea i’m a huge fan! i never use the analog speedometer on the right screen, always have the digital one on the left. you can still pull it up but of course it replaces the carplay display.
    i haven’t tried since i’m always on carplay and i can easily answer phone calls with the selector on the right side of the dash when the alert comes up, but i think you can still answer with the phone button on the steering wheel. you can also pull up siri with the voice control button on the steering wheel.
    not really many downsides to it that i can tell, it generally has worked really well and main issues i’ve run into are not really specific to this unit in particular. for example if you want to type to search on maps it takes forever to go back and forth finding letters, but that’s just an issue of carplay in this car, not of the third party implementation cause if you had carplay from factory it’d do the same exact thing. all in all i don’t think there’s any major issues with it and i’m so happy i got it, it’s made driving (especially for longer trips, like when we drove ~500mi to vegas for F1) so much easier by just having the directions up on the screen vs having to use my phone. i’ve always liked carplay so i’m biased, but after driving the same car for about a year without it and later installing it, i’m actually surprised by how much of an improvement i felt. even bigger than i expected.
    of course id prefer the factory install, switching between carplay and the system menu reminds you this is a third party implementation. but as far as i can tell getting the factory version is not possible, and i don’t need to do that often so it doesn’t bother me too much. i’ll take this implementation over none at all any day.
  19. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    Thanks for the answer, the factory system in no good for me as I use Android Android phone so need Android Auto that was not available for the 812.
    mnl likes this.
  20. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    Can you do me a favor please, I have the unit installed but can't find Android Auto.
    I see car play.
    My phone is blue totthe to my car and the unit.
  21. mnl
    mnl Rookie
    Jul 12, 2023
    31
    i dont have an android phone so not sure how that works, i guess it must be through huawei or mirroring? this is what i see on my end: https://imgur.com/a/vgD57pj
  22. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    That's the exact screen I have, when I go to the carplay icon it says phone not connected.
    I am blutooth to the car and the unit. It will play music.
    Did you need to wifi your phone to the unit, when I try that I get a 6 number code but my phone needs 8 numbers.
  23. mnl
    mnl Rookie
    Jul 12, 2023
    31
    technically yes it uses wifi, but i don’t configure that. iOS handles connecting to wifi on its own to connect to carplay, i just needed to connect to bluetooth
  24. RBRS1955
    RBRS1955 Rookie
    Nov 2, 2024
    38
    Russell Boxall
    Thanks, I got hold of them in HongKong or China.
    Seems like in settings there are a bunch of parameters that can be changed, they are trying and I'm hopeful but everytime a change is made i need to wait 10mins for the unit to discharge.
    Seems the setting that kept generating the 6 didgit code was a dedicated Huwari phone app.
  25. mnl
    mnl Rookie
    Jul 12, 2023
    31
    oh nice, glad they’re helping you out, hopefully you can get it sorted soon!
