Adventures of a 95 Verde Mugello GT | Page 3 | FerrariChat
Discussion in '456/550/575' started by Aerosurfer, Jan 19, 2022.
  1. AWK166
    AWK166 Karting
    Oct 9, 2020
    51
    Andrew King
    Synthetic clay is super easy and really gratifying. Depending on scratches use their complete compound or complete polish with a grey griots foam pad and I then finish with poly wax and spray the 3 in 1 ceramic wax on top. Silky smooth
  2. Aerosurfer
    Aerosurfer Formula 3
    1,815
    Indianapolis
    Nick
    tbjo1, AWK166, Mirek and 1 other person like this.
  3. tazandjan
    39,063
    Save the frame and you can put in new filter material easily. Never seen one that dirty, so good idea to change.
    NYC Fred, AWK166 and Aerosurfer like this.
  4. r-mm
    r-mm Karting
    Aug 8, 2012
    71
    Great stuff here - as someone who has always fixed it himself conventions be damned, this thread warms my heart. The colorway pains me with desire. If you wanna trade for my 964 C4 you know where to find me ;)
  5. Aerosurfer
    1,815
    Indianapolis
    Nick
    #55 Aerosurfer, Mar 8, 2022
    Today, after a nice drive across town, I decided to flush out my Transaxle fluid.
    As other have said on here, this car is enjoyable to work on myself. I dont have any history of the rear end being serviced, so i figured as i sort thru i would start the clock over again. This is an easy (with basic tools... oh and a lift) job.
    Gear oil certainly has a very distinctive stink to it. Old stuff came out dark and smelly. Drain plug has some metallic sludge on it. Pulled the screen too. Im not sure how little debris is considered acceptable, it wasnt none, but im not concerned with what came out. Fill dipstick was low however, only about 3.5 liters of Old fluid out....I did push 1/4L or so to flush through new fluid and redrain.
    New Redline 75w90ns went in.... put a little over 5L in, went for a drive and pumped just a bit more in to top the dipstick mark. Screen has a build date of 1994, nice to see old, but quality parts onboard. Before and after, box was dry on the outside. Didnt notice any difference in shifting quality, at least with cold oil. Will hopefully get out and up to temp more this week.
  6. Aerosurfer
    1,815
    Indianapolis
    Nick
    Sludgy drain plug and cleaned screen
  7. Aerosurfer
    1,815
    Indianapolis
    Nick
  8. Aerosurfer
    1,815
    Indianapolis
    Nick
    So begins (and nearly finishes) my Fuel pump overhaul...
    Had a local car show i was invited to cancel due to expected weather, of course the day after i had just put 10Gal of gas in... had intentionally been keeping it low, in anticipation of this fuel pump project...
    So began with section a hose off the left side schrader valve into tubing to my gas can. I did end up just making a jumper and pulling the fuel pump relay on that side. With fire extinguishers around the car at the ready and my garage open, i contred the fuel pump flow right at the battery cutoff switch. I had really overthought the process, this was incredibly easy to drwin the tanks. Fuel came out clear so it just got dumped between my M3 and my truck. With the 10 i had juat put in and whatever turns the low fuel light on, i pulled about 13 gallons out of the car before the fuel pump started to wine.....
    Step 1
  9. Aerosurfer
    1,815
    Indianapolis
    Nick
    Now it was time to open the covers. I modified a universal fuel pump removal tool for our cars. This worked perfect to remove the ring nut...
    Lots of pads in the trunk and some plastic liner to protect from gas and dirty tools.
    Once the ring nut was off, a steady but light pull on the stud bith removed the fuel lines and made the cover give up its secrets!
    Fortunately neither has any visual cracks, nor was there any fuel odor. 27 year old gasket was pliable, but well sealed to the tank, had to use a pic to get it started out.
  10. Aerosurfer
    1,815
    Indianapolis
    Nick
    NE550 likes this.
  11. Aerosurfer
    1,815
    Indianapolis
    Nick
    As for the inside of the tank... the pad that sits under the pump assembly was completely gone. Only a few large chunks left and some smaller bits. I did what i could getting the pieces out, but since there was still a small volume of gasoline in the tank it made grabbing the tiny pieces tough. Even my siphon couldn't pull any more out. Had to work carefully! I figure if the rest of the pads had already gone thru the pump and to the filter a few stray bits arent going to matter in the future. I used a different material recommended to me from anotherbuser on here as the anti chafe pad.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    NE550 likes this.
  12. Aerosurfer
    1,815
    Indianapolis
    Nick
    As for the pumps themselves, Fabios fuel pump supports fit like a charm!
    I was very torn what to do with the assembly, ultimately i left the original fuel hoses after inspecting what i could. The connections on each end didnt seem worth the risk opening or doing improperly not taking the chance of damaging the cover. I washed out all the rubber bits and debris and buttoned it all back up. Then swapped out the fuel filters. What a messy job that was (nearly). Very tight space on those banjo bolts.
    Thats where the story ends at the moment... ran into our evening plans. Wife lets me play Ferrari Mechanic... I take her out! Today is even colder and full of plans. I leave for my next trip tomorrow evening, so i may be aome time before i get to finish this out...
    Plan to fill 10 gallons or so and check for leaks at the cover, then pressurized system and check for leaks at the filters... then hopefully the magic happens and i notice a difference. I will also eventually cut open my old filters and hopefully see them full of choked off debris as conclusive evidence to my performance degradation
    Boomhauer, NE550 and tantumaude like this.
  13. Mirek
    Mirek Formula 3
    1,470
    Los Angeles, CA
    Mirek
    That is enjoyable to read and thank you for those pics, I recently had much of this work done so it is interesting to see and hear the detail.
    I also went with Fabio’s pump supports and am also super curious what is inside your fuel filters.
    The previous owner of my car had fuel filter changed, had the injectors balanced and had the car dyno tuned all because it was low on power. I suspect the root cause may have been the disintegrating fuel pump supports gumming up the works. My 456M is MUCH faster than when I got it. I had a lot of stuff done to get it up to snuff though.
    Are you tackling the rollover valves ? They were the cause of my fuel smell which led to all of the fuel tank work I had to have done.
  14. Aerosurfer
    1,815
    Indianapolis
    Nick
    Thanks for reading, it was a fun day.... cold and somewhat stressfull (being cognizant of working with open gasoline).
    I had no gas smell prior to starting this. I read about the rollover valves, but not sure what i need to do or should at this point with them. I did see the plumbing tucked in the far left side of the tank.. seems near imposible to reach effectively. Dont plan to pull the tank if i dont have to.
    What else was done to yours? If this doesnt fix my issue, im not sure what to proceed next. Injector service and/or possibly pull the center pipe to get a look at the condition of the Cats ‍
    Im all for hitting deferred and overdue maintenance, but dont necessarily want to simply shotgun parts at it.
  15. Mirek
    Mirek Formula 3
    1,470
    Los Angeles, CA
    Mirek
    #67 Mirek, Mar 12, 2022
    What is the nature of the issue ? Does the idle stumble upon cold start ? My car stopped doing that after I replaced the fuel tank rubber AND the gas smell stopped. It was a great repair.
    In the last 3 years I have had the throttle linkage lubed & adjusted, fuel tank rubber replaced, full major performed, new radiator, new alternator, 4 new O2 sensors ($2k), Fabio muffler deletes…I cannot point to exactly what led to the most improvement — but it kind of took all of that.
    One weird thing….a top independent out here in LA was lubing/adjusting my throttle linkage looking to improve throttle response and was remarkably surprised at a modification he was able to make down at/in/around the throttle pedal somewhere. He indicated there was a “bump” or some factory “thing” limiting travel or something like that. He said he had never noticed it before. He was somewhat bemused and it was easy to “modify” he felt it was there to protect the transmission from abuse or something. It has always bugged me that I do not know exactly what he did.
    Also I recommend the Hill Engineering pedals!
    NE550 likes this.
  16. Aerosurfer
    1,815
    Indianapolis
    Nick
    #68 Aerosurfer, Mar 12, 2022
    Car starts and idles beautifly. Could nearly balance a coin on its side. Hot or cold. No smoke on startup. It simply feels anemic below 4000 RPM. Not stumbling, just feels like there is low power or slow acceleration. At speed it feels, sounds, and cruises fine.
    Major done in 2019 (only 500 miles ago)
    Compression and leakdown done at PPI in January
    Accelerator cable checked and TBs opening fully
    Rambling thoughts or WAG on what else and assuming i can trust my records and ppi...
    Cats blocked..
    injectors leaking or not flowing properly
    O2 sensors need work or other component issues.
    Clutch/Throwout bearing isnt fully disengaging.
    None of the above i would expect as smooth as it already runs. I do look forward to hopefully seeing some return of performance from the fuel pump overhaul
    For a car that on paper should be nearly as fast as my M3, it just isnt and noticeably so. I dont expect a raw sports car, but seems like there should be more ooomph
    I wish i could drive another to compare my expectations. Youtube videos seem to show faster acceleration and RPM movement than i think i presently have
  17. Aerosurfer
    1,815
    Indianapolis
    Nick
  18. Aerosurfer
    1,815
    Indianapolis
    Nick
    Its alive again! And Holey Googily-Moogily do I have a fast car now!
    So I got the fuel pumps back together without issues, no leaks, new filters. Pressurized the system with a jumper at the relays and she fired right up and idles smooth and without any fuel smell (that was never an issue)
    But as of yesterday, still had the anemic performance unchanged...
    Now lets move to today, after reading the Workshop Manual a little more indepth, I remembered there was a broken plastic arm under the right side Throttle body. I had looked at it before but dismissed it as a support piece. Turns out it moves the valve for the hall sensor on the TB!
    According to the part lists, its not available by itself, however its only held on by a few Circlips. Not wanting to take it apart before testing, i reglued it together and fabricated a bit of a splint around it with some coat hanger type wire and secured it with both safety wire and a zip tie. After also cleaning all electrical connectors, swapping out both Fuel pump and Injector relays with new Bosch parts Aaaaaaannnd checking and shining up the metal tangs on all the fuses. It was time for a startup yet again.
    Its amazing and instant the throttle reaponse now. The car finally pulls like a 440hp V12! All gears will accelerate now. Low end power is what was missing, that is Criminally abundant now! I'm still grinning ear to ear! I knew i wasnt crazy when i thought the car was missing something.
    Apparently the last few months and beyond, its essentially been a 6 Cylinder, dragging along another 6 cylinder.
    I do have a 1-6 CEL thats become semi intermittent now. That started yesterday when i began removing and cleaning all connectors. I rechecked everything today, except the O2 sensors, but the light persists. What kind of condition could the motor be in with one side running/one side idling, yet the TB being pulled open by the cable?
    I ordered a pair of new O2 sensors (Motronic 2.7 only 2 sensors) and will have those at the ready.
    NE550 and halr75 like this.
  19. Aerosurfer
    1,815
    Indianapolis
    Nick
  20. Mirek
    Mirek Formula 3
    1,470
    Los Angeles, CA
    Mirek
    I applaud your technical skills and LOVE that your 456 is so much more fun to drive !
    Congrats on the diagnosis and repair, your car has a good owner.
    tantumaude likes this.
  21. r-mm
    r-mm Karting
    Aug 8, 2012
    71
    I've 3D printed several engine bay parts in Nylon or Nylon-X as Matterhackers calls their excellen fiber reinforced nylon. Its also an excellent candidate for cheap laser cutting at Send Cut Send. They do not do any 2.5 or 3D features however and I can't tell if that part can be simplified to 2D or not.
    You are not making me want a 456 daily drive any less!
  22. Aerosurfer
    1,815
    Indianapolis
    Nick
    It has been fun indeed! In my 25 years or so of tinkering and building automobiles, todays victory was about as exhilarating as my first engine start after a rebuild. Rare that a fix makes such a conclusive and total result changing everything about the car! Still smiling as I write this. I have awakened the beast!
    I know not everyone works on their cars for whatever reason, and this is in no way meant to sound condescending, but as amazing as a Ferrari is (or Porsche, or VW or even a barely running Honda) it’s still just mechanical pieces and parts. The wealth of knowledge is certainly out there, and easier than ever to attain. I have come to believe most things are more intuitive or easier to learn than one would believe, just use common sense and proper tools. The addiction snowballs quick.
    I’ll revisit a more permanent solution to my TB potentiometer arm after I get back from Vacation.
  23. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    Love it that you (like me) just tackle what comes up and I recognize the immense joy when something that has been bothering me for days/weeks/months finaly comes together. I guess you'll agree that these cars are fun and not particularly difficult to work on, just time consuming. And very rewarding!
    Aerosurfer likes this.
