Aftermarket headers, plasma white ceramic coat no blanket req?! | FerrariChat
Discussion in '360/430' started by chillo, May 12, 2014.
  1. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    I have a set of agency power headers on order (F430 spider), they are being finished with a plasma white ceramic coating (as applied to race car headers)
    I believe this will provide a sufficient thermal barrier as to not require blankets.
    Has anyone used anything similar or has experience of?
    I know voicey has black ceramic headers and has not had any heat soak issues, white finish should run cooler temps in the engine bay.
  2. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    No one considered doing this then?!
  3. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,394
    Honolulu
    Kevin
    I would post this up in the technical Q&A section for more hits.
  4. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I've used ceramic coated headers on two of my racecars. I left the first set white, which got discolored quickly. I painted the second set flat black, with hi temp exhaust paint. Color does not make a difference, since they are not subject to external radiant heat. The principal heat transfer mechanisms are conductive and convective.
  5. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Agree, color is more of a preference. In the "old days", headers were painted white for a reason: so you could easily see when cracks formed as the exhaust would leave a carbon trail.
    Insulator blankets have several potential benefits, and reducing engine bay temps is only one of them. Another is to reduce fire hazard risk. A relatively small amount of oil that leaks onto a header can ignite quickly and engulf a car in flames. A header blanket theoretically reduces this risk by absorbing the oil and lessening chance of combustion.
  6. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    I usually tell my customers that if they are using my header blankets while their car burns down, they will have a nice set of headers and blankets they can sell afterwards! LOL, but I can also highly recommend the blankets for track cars, their effective heat range is much higher.
  7. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
  8. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    #9 chillo, Jun 17, 2014
  9. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    #10 chillo, Jun 17, 2014
  10. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    What's the cost difference between the two?
  11. V8ray
    V8ray Formula Junior
    Jun 18, 2013
    251
    Ray
    #12 V8ray, Jun 17, 2014
  12. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    I installed a set of Fabspeed headers with white ceramic coating last month. No blankets.
    I have not tracked the car, but did do a 500 mile spirited run a few Sundays ago and felt that the engine compartment temp was lower. Normally, when I shut down, I pop the lid and it was not "fried egg on glass" hot.
  13. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Like it! :D
  14. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    $400 for the white coating as used in the race cars, $200 for standard black coating
  15. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    That's good to hear! Have heard great reports similar to what you have found with the white coating.
  16. 360Tom
    360Tom Formula 3
    May 9, 2013
    1,396
    Burbank, CA
    Tom
    Be interesting to see what keeps the engine bay cooler, the blanket wrap or the ceramic coating?
  17. Rifledriver
    36,855
    From crewing on 2 land speed record cars, one a 700hp 370 inch Rodac Chevy Lakester and the other a Falconer 250 inch 1300hp Chevy in a Streamliner any coating tried was nowhere near as effective as wraps and blankets.
  18. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
    No real suprise there though as that is being used in an environment way beyond street :)
    But what about road cars/occasional track day?
  19. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Still wrap would make the bay cooler... But how much, and is it necessary? Blankets also take up more space and I imagine restrict some of airflow around the headers which might otherwise be beneficial. I'm sure no one has done a before and after test on a 360/430 that is reliable... So it just depends what you are comfortable with. I went with white ceramic, skipped the blankets, and cut a couple of naca ducts in the front portion of the floor (in the challenge locations) to promote airflow at speed and take some of the heat away from the alternator.
  20. Evan.Fiorentino
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    I like to think of the blankets as a preventative maintenance item for street cars.They do give piece of mind to people who use their cars in a more aggressive manner or environment for extended time periods. Personally, I would consider them necessary for track cars and well worth the investment.
  21. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
  22. chillo
    chillo Karting
    Mar 18, 2009
    54
    East Yorks, England
    Simon
  23. Dano360NC
    Dano360NC Karting
    Aug 11, 2012
    167
    Southeastern PA
    Dan
    I recently installed (by local Indie) Fabspeed headers and a new Ferrari Racing Exhaust on my 360. Dealers have been selling the racing exhaust for about half price. The headers were ceramic coated, wrapped in exhaust header tape followed by blankets. After driving and popping the rear deck lid, the engine bay is way cooler than previously with most of the heat evolved probably coming from the components other than the headers. It is noticeable. I like the new set up a lot and it should help preserve the life of the air conditioning compressor and alternator which are relatively close to the headers.
  24. Joe@Fabspeed
    Joe@Fabspeed Karting
    Sponsor
    Jul 1, 2005
    240
    Philadelphia
    Joe Fabiani
    It's joe at fabspeed Motorsport.
    I designed and dyno developed fabspeed Ferrari headers long ago and everything is fabricated from type 304 L (L signifies low carbon) .
    We have installed and sold many polished sets therefore un coated polished of ferrari 355, 360 and 430 headers and have had no problems in any drivers education and hot and humid environments. No fires and no issues or I would have heard about it and been sued.
    My 360 spider has had polished uncoated headers on it for years with absolutely no ill affects. None whatsoever. Fabspeed designed and offers stainless steel reflective heat shields for the A/C compressor and alternator for our Ferrari 355 and 360 headers.
    On the 430 and 458 Ferrari moved all these components far away so heat is a non issue.
    With all the above Ferrari owners can of course get their high performance headers ceramic coated by numerous vendors and of course that helps insulate and keep some of the heat generated inside the header tubes. Fabspeed offers that service as well.
    Finally last year our engineers designed, engineered and tested aerospace style thermal
    blankets for Ferrari 355, 360 and 430 headers. These fabspeed Ferrari header blankets are super simple to install and remove. You first install our headers and then our blankets are supr simple to install as they are designed to wrap around the header primary pipes and have stainless steel springs and attachment clips. It's a doit yourself project. Our blankets should work on any and all aftermarket Ferrari headers.
    Bottom line you can run polished, get headers coated and or install thermal blankets. No matter what a good set of headers really wakes up the sportscar sound, power and protects your Ferrari engine versus OEM headers. Cruise by our shop I have all kinds of factory Ferrari headers cut open and our systems to be viewed side by side.
