All lights out | FerrariChat
All lights out
Discussion in '206/246' started by Tabletcounter, Oct 4, 2015.
  1. Tabletcounter
    Tabletcounter Karting
    159
    Cheshire UK
    I came to put on my headlights today and got nothing. No sidelights, headlights (dipped or full beam) or rear lights. Fuses are all good. I've only checked a couple of the bulbs but they were good and I can't see all the bulbs going at once. I'm not sure about the relays but assume there are more than one and they won't fail together.
    Everything else is good - brake lights, indicators interior lights etc and the car runs fine.
    What else should I be looking at?
  2. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    check, power to relay, there are two so find out which is light relay
    forr all lights to go out the only thing it could be is the relay I am most sure
    clay
  3. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
    earthing problem.
  4. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    160
    Los Angeles
    Jim Oddie
    Could also be failure of the switch on the steering column stalk.
    Hopefully it's the relay because its easier to fix.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I would start further up stream and check power at the fuse block. Each headlight has its own separate 25Amp fuse in the rear two fuse block positions and you can't get a more handy place for a test point.
