News
Alternator repairs - 348 and others
Discussion in 'United Kingdom' started by jkuk, Sep 7, 2004.
  1. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    Just had my 348 alternator re-built (Nippon-denso type) - £95.
    Just passing on the knowledge. - www.nippon-dis.co.uk.
    Located in Sutton Coldfield - Midlands.
    Apparently these can fail if they get oil leaks dripping on them (what - a leaking Ferrari - never.).
    Cheers
  3. dpsuk999
    dpsuk999 Formula Junior
    Feb 12, 2004
    264
    Leeds UK
    Dave
    Thanks for posting that. You must be nearly there now getting the car sorted, I think by the time you have finished you will have replaced all the major components.
    Are you going to see-red?
  4. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
    Hi Dave,
    It certainly feels like I have replaced everything.
    Once I get the a/c working the car's perfect - but I will leave that for a while.
    I may be off to 'see red' on the Sunday, it depends if previous committments fall through - hopefully
    cheers
  5. Dem
    Dem Formula 3
    Mar 21, 2004
    1,023
    London
    Dem
    That's a decent price depending on what they fixed and how they did it. If oil dripped into it, the chances are that the brushes wore out very quickly, so it shouldn't have taken to much to repair it (new brush box assy).
    For reference, if anyone wants a replacement F355 alternator from this company, the part number is 101211-7540. I know this, cos my boss and I designed it! I think I mentioned it on the tech forum a little while ago, but in case anyone missed it, if you have any starter / alternator queries I may be able to give advice but don't expect too much!
  6. trevi
    trevi F1 Rookie
    May 19, 2003
    2,619
    Switzerland
    these can always fail...for any reason, had mine repaired for the fifth time now in 5 years! that means be stranded somewhere in the woods, trying to get back to civilization before the battery is empty :)
  8. jkuk
    jkuk Formula Junior
    Nov 3, 2003
    259
    Wirral, UK
    John K
  9. Dem
    Dem Formula 3
    Mar 21, 2004
    1,023
    London
    Dem
    Sounds fair enough to me! They are correct that anything that gets in there, be it water or oil, does act as a grinding paste and destroys the brushes. About £3 worth of bits, but given labour time and the fact they need to make some money, you can't grumble.
    I'm trying to find a source for at least the brush boxes (other than pulling in favours from my colleagues in Japan!), because that type of alternator is so easy to repair once you have the parts.
