Another stupid 348 transaxle question | FerrariChat
Discussion in 'Technical Q&A' started by spider348, Feb 15, 2004.
  1. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Another question. Thank you for all the help thus far.
    Assembling my gearbox. Replacing all the bearings. Stuck at the 2 main tapered differential bearings.
    Problem: Cannot remove the inner race with roller cage. 1 side has virtually no clearance the other some. Ground a cheap 3-arm puller to fit the side with some clearance. Low heat on the race. Outer race in place to prevent cage collapse. No luck.
    Haven’t attacked the opposite side yet.
    Question: There are 4 holes behind the inner race, appear to be oil feed holes. Do I have to disassemble the differential unit and drive the inner races out through those 4 holes?
    Is there a better way to remove the bearings that I am missing?
    Again, thank you. John.
  2. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Sorry for the wasted post. Disassembled differential, bearings off. Should have asked before I wasted 3 hours trying to pull the bearings. Live and learn. Thanks, John.
