Any Tips for Burnout at Start?? | Page 2 | FerrariChat
Discussion in '348/355' started by Nero308, Apr 28, 2009.
  1. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie Rossa Subscribed
    Jun 9, 2004
    4,686
    LA & OKC
    Kevin
    Put it in 1st gear
    Hold brake with left foot to prevent from going into N.
    Release brake and immediately floor your throttle to 100%, do not hesitate.
    The car will rev to 7.5k and launch from there.
    I've launched my car this way over 100 times, 13 times at a dragstrip. I can consistently get 1.55-1.60 60 ft's. I'm on original clutch.
    That's not to say you should not take Brian's advice as he has more experience then any of us do, I just never have had an issue using the F1 launching.
  2. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    That's right Kevin, mid engine cars are great for good solid launches....
    I think what Yoshi wants to do is a burn out, just sit on the spot with clouds of smoke coming off the rears.
  3. Tomax
    Tomax Karting
    Apr 27, 2004
    217
    Maybe do what TOPGEAR live did and use Toyotas with Ferrari kit-car tops. Those Toyota clutches are much cheaper to fix. One I'm suprised no-one has put forward is a good amount of cheap cooking oil. That will take the pressure off your clutch a little and help with the smoke. Also if it's something you want to do again and again - have a friend record it and make it an AVI. Hitting the spacebar again and again will be very easy on the clutch.
  4. J. Salmon
    J. Salmon F1 Rookie Owner Rossa Subscribed
    Aug 27, 2005
    4,367
    VA
    People keep talking about burning clutches. Once you dump it (clutch clamps shut) and connect the motor to the rear wheels, you are not going to burn your clutch. Dumping the clutch is not bad for the clutch at all, in fact it will cause almost no wear. The shock of the clutch suddenly clamping down with a spinning motor and stationary wheels is transmitted through the driveline, and that is where you can do damage. Once the wheels are spinning, you are simply burning rubber.
    You will only burn your clutch if you slip it. If clutch life is your goal, burnouts are your answer. But you are going to pay in tires and (possibly) gears.
    Just thought I would clear that up.
  5. mjw599
    mjw599 Formula Junior BANNED
    Jul 30, 2008
    510
    A Chinese Democracy
  6. RossoCorsaItaly
    Jun 9, 2004
    4,686
    LA & OKC
    Kevin
    Whoops, my misunderstanding.
    In that case spend $2,500 on a 95 Camaro Z28 and you can burnout all day long. :)
  7. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Ka-ching!
    He obviously has never seen the inside of that gearbox and how tiny some of the important parts are. ;)
    Here are a few photos from an earlier thread:
  8. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LMAO!
  9. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,418
    Houston, Texas
    Bubba
    The smoke is from the bleach as well the tires, in drag strip applications.....:rolleyes:
    I settle for a little 'chirp' from the tires, myself......
  10. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Hi Yoshi,
    I see you are from my neck of the woods. I would be very careful about where you burn rubber.
    I squealed the tires on my 01 Trans Am WS6 several years ago and found out the hard way that it is not a good idea to do burnouts in California. Apparently, burnouts = competitive racing = worse than DUI. They not only arrest you and take you to jail, they also jail anyone who is watching. To make it worse, they impound your car for 90 days. It is usually about $100/day for the impound lot. The insurance companies will also refuse to insure you. I became uninsurable for 3 years and the offense stays on your record for 7 years.
    When I lived in Indiana, a burnout was just a $25 unsafe start ticket.
  11. Rifledriver
    37,350
    Clutch shaft and clutch shaft gears eat it with regularity and so do 1st gears. 1st is a little bitty thing and sometimes they just break in half. That not too bad unless the halves get between the other gears. Then you just throw the whole thing in a dumpster because there isn't enought left to fix.
    I love people like this. Going to help me retire well. They have a real disconnect about other people breaking things and their own behavior.
  12. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It is job security (as long as the parts hold out). :D
  13. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
  14. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Cool pics! :D:D
    I would have to sell my first born son to pay for damage like that! :eek::eek:
  15. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I guess that big poser wing doesn't improve rear wheel traction much when going sideways.
  16. J. Salmon
    Aug 27, 2005
    4,367
    VA
    So it sounds like a 1-2 shift would be a bit safer, as you are not loading first gear. It's unusual for me to even shift into second hard, but 2-3 happens with some regularity.
    Is the clutch shaft built as a weak link, almost like a fuse?
    Again, do you see many failures with regular "spirited" use? I never dump first gear. But I love to drive the car in the mountains in sport mode and the shifts are pretty abrupt. Actually, I am not sure why I am asking, since I don't think it will change my habits. I mean, if you cannot drive the car and enjoy it, what is the point? I guess I could move it out of sport and let the clutch take some of the abuse.
  17. Night life
    Night life F1 Veteran Silver Subscribed
    Dec 1, 2007
    7,325
    The city that rhymes with fun in Canada
    Roberto
  18. Rifledriver
    37,350
    No. It just happens to be the part that broke on that one.
    Ferrari transmissions are not made for hard launches. In another 5 years the 355 guys will have a long list of posts about blown up transmissions just like the TR and Boxer guys, and the 348 guys do now. 15 or 20 years ago it was the Daytona guys.
    Many dealers and independants do not do major transmission work. I do so many of them come my way. My scrap metal guy is getting rich on the broken Ferrari transaxle parts I throw away.
  19. mseals
    mseals Two Time F1 World Champ Lifetime Rossa Owner
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
  20. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Looks like its time to buy shares in 355 gearboxes eh?? :D:D
  21. Etcetera
    Etcetera Two Time F1 World Champ Rossa Subscribed Silver Subscribed
    Dec 7, 2003
    24,396
    C6H14O5
    Not in the gearboxxen themselves, but in the repair thereof.
    I own an Enzo with the rare 4L80E automatic option and trust me when I say that I can roast the tires down through the rubber, wheels, brake discs and cv joints all I want, all day...zero problems.
    BTW, you can look up my Enzo in the Enzo Registry under the license plate of PRNDL.
    Foot+gas pedal+firewall is all a guy needs for maximum performance.
  22. Etcetera
    Dec 7, 2003
    24,396
    C6H14O5
    I'd guess that none of the components are built as a weak link or "fuse" in your vernacular, but a combination of a desire for the reduction of drivetrain loss due to lighter components and cost saving measures.
    But then, I am inexpert in this area.
  23. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Sounds like an amazing machine Carl! :D:D
