Anyone using Champion RA6HG plugs in a 328? | FerrariChat
Discussion in 'Technical Q&A' started by peajay, Dec 13, 2003.
  1. peajay
    peajay Formula Junior
    Apr 17, 2002
    454
    near Paris, France
    Paul
    When I got my 328 it had Champion A6G plugs installed, these are the correct spec. plugs called out in the Ferrari manaul, they have the uncommon 18mm size hex and the small diameter wire electrode. When I tried to buy new ones I found that they have been superceded by RA6HC part number whch has standard diameter electrode but short insulator ( presumably to give similar performance) they have also gone back to the more standard 16mm hex by the way. However, I am just about to install them and see that although the thread length is the same, the working bits on the end cause the overall immersion length to be about 0.060 inch longer. So I was wondering has anyone been using these plugs ? I presume there is enough clearance, but I'd rather be safe and ask here before I use them.
  3. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    we should start a spreadsheet of plugs for various cars and get rob to post it in the service area.
    FOR 328--I have these
    Bosch XR4-CS-standard plug
    NGK DR8-EIX irridium plug
    FOR 308 4v
    NGK BP5-ES HOT
    NGK BP6-ES Standard
    NGK BP7-ES Cool ( for hi voltage systems)
  4. atheyg
    atheyg Guest
    Champions are the poorest quality plug out there.
    They used to be good, but every vehicle I have seen them in the plugs are severely pitted and corroded with pieces of electrode missing which had to have been pushed out by the pistons and valves, do your car a favor and get NGKs
  5. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    I recommend the NGK's also. They are not only a great plug, they have the 18mm hex also!
  6. peajay
    Apr 17, 2002
    454
    near Paris, France
    Paul
    Hmmmm.... I have driven how don't know how many thousand miles over the past thirty years, and never had a failed plug using Champions, or any other brand come to that, I would suspect that all plugs are pretty much the same from the reliability point of view. The only question I have is does the extra 1/16 inch (1.5mm) length make a difference, of course I don't have another brand plug to compare length, just old part number versus new part number.
  7. atlantaman
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    I tried champions and threw them away--go get some NGK plugs and you will be a lot happier
