bad azzz boxer part III | Page 11 | FerrariChat
Discussion in 'Boxers/TR/M' started by riverflyer, Apr 29, 2016.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nothing like a Black Ferrari. Nice work, Paul.
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Truth.
    Loving this thread. Thanks for sharing your work with us, Paul. Such a cool build. :)
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,519
    Canada
    Newman
    #253 Newman, Jul 14, 2017
    Wiring is done. All modules are hidden in the cabin, no visible wiring. I placed the coil packs on the firewall ahead of the engine right behind the passenger. They are mounted closer to the bottom so not obvious from above unless you really look. Im using the 512M wire retainers vs what the testarossa used and making my own wires with spiral core 8mm wires. The fuel rails posed some problems as did the existing fuel system. The first problem is the current fuel system had the filters on the inlet side of the pumps (not on the outlets) which can cause cavitation so Im putting two OEM bosch filters on that an injected boxer or 400i would use and putting them after the pumps which is easy. Im also putting in an inertia switch inside the passenger compartment as a safety measure in case of an accident.
    This leads me to the 2nd hurdle which is the compatibility of the bosch stuff to an -6 fitting. Mirror images of each other and thread complications. I finally just made my own adapters to bridge the gap from the flare -6 fitting to the bosch fuel rail that required a ball / socket arrangement. Running the hose is a cake-walk now. The fittings were a headache, I would like to plate them or make them look prettier but im happy with how im plumbing the supply and return.
  4. dwhite
    dwhite F1 Rookie
    So when is the first lucky bastard going to drive that beauty?
  5. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    That would be me....
    Just finishing up plug wires and the fuel lines. Configure the program to this engine and twist the key.
  6. dwhite
    dwhite F1 Rookie
    I figured it would/should be you. What a drive that will be once you've determined everything is okay and now it's time to test the "BadAss" in this Boxer. Try and make a video or is that obvious. Oh yeah, enjoy.
  7. MobileJay
    MobileJay Formula 3
    1,442
    Houston
    Jason Cavallo
    Absolutely incredible the amount of work and passion you are putting into this. You need to have at least a cell phone video of the first key turn haha.
  8. ago car nut
    ago car nut F1 Veteran
    5,521
    Madison Ohio
    David A.
    Paul,
    Did you silver solder the adapters for the fittings?
  9. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    No I used brass. The original banjo fittings on the CIS fuel supply lines are brazed on. Silver solder was considered but its strength concerned me. The tubes are inserted 1/4" to 3/8" inside the threaded elbows that I modified.
  10. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    #260 Newman, Jul 17, 2017
  11. ago car nut
    5,521
    Madison Ohio
    David A.
    Silver solder can be very strong if assembled like a sweat fit. I believe the early Crosley engine blocks were furnace silver soldered before they cast them from Iron. I read a book on silver brazing assemblies that were low production.
  12. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    Agreed. I doubt either would be an issue, just felt better going with brass.
  13. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    #263 Newman, Jul 19, 2017
  14. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    #264 Newman, Jul 19, 2017
  15. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    #265 Newman, Jul 20, 2017
  16. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    #266 Newman, Jul 20, 2017
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Love the plug wires :)
  18. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,280
    Mel
    Very, very nicely done ... Q: no cilinder numbering on the plug wiring ?
  19. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    IT'S ALIVE!!!
    Running a little fat so tomorrow Ill pull fuel out of it and fine tune. I took a video but don't know how to post it or where else to post it with a link.
    Celebrating with a glass of Baileys.
  20. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,589
    romano schwabel
    GRADULATION ! ! !
    but only 1 glas of baileys - hope a large one - and ice cold :)
    you may post it at youtube
  21. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    Ill try to add it on youtube then post a link. Sounds like a BBLM for now ;)
  22. Newman
    Dec 26, 2001
    14,519
    Canada
    Newman
    you tube link
    Remember, first time running since 96 and it had run 3 seconds prior to me hitting record and shut it off at the end of the video. Its running rich and the exhaust is only mocked up with tack welds.
    https://youtu.be/3HgtG0SFqwI
  23. turbo-joe
    Apr 6, 2008
    9,589
    romano schwabel
    sounds good for not adjusting right until now
  24. Melvok
    Jul 25, 2008
    14,280
    Mel
    Congratulations ! Sounds like a racecar for now :D
  25. 4right
    4right F1 Rookie
    Looks and sounds great! I find the best way to accomplish anything electronic or computer related especially video these days is to ask the kids. Simple for them!
