430 - Battery question?? Car doesnt start well | FerrariChat
430 Battery question?? Car doesnt start well
Discussion in '360/430' started by craze, Dec 26, 2021.
  1. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
    Just hoping for some advice
    Got my f430 1 yr ago
    Sat in dealer for 6 months not on tender
    Battery was apparently replaced prior to receiving it
    I always put it on tender ctek mks5
    In winter when it got colder i noticed sometimes id get the rough start
    Anyway car was at dealer for 2 months and apparently it wouldnt start a cell collapsed in battery
    Apparently changed under warranty
    It had been on for few months but now after f1 primes voltage is 11.9-12.1v, and often rough starts and if u shut off and start again often the error with 2 triangles comes up
    I checked and battery thats in it is a cheap supercrank $120usd battery
    I just replaced it with a yuasa agm was around $320usd
    Was my rough starts and above indicating lazy battery?
    Tender always showed charged
    When battery was new no rough idles
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    A general guide is the voltage the battery drops too when you push the start button, too low and it will only run on one bank and be lumpy
  3. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
    Thank you
  4. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    I suggest getting a Battery Load Tester. Amazon has them for $40-$50. You simply put the alligator clips on the battery terminals and push the button. It will tell you when your battery under load, is getting weak. They are nice to have in the garage for other cars, motorcycles, etc.
    It sounds like yours was getting weak. 11.9 - 12.1 is too low for a resting battery. The voltage probably dropped way more when you hit the start button.
    craze likes this.
  5. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
    Apparently when turning over around 10v is ok
    Started car today with new agm and rough idle
    however restart no triangle suspension warning
    Ill try to let key initialize for 15 seconds prior to starting
