Battery Shield Questions | FerrariChat
Discussion in '456/550/575' started by BillN, Apr 14, 2019.
  1. BillN
    BillN Karting
    144
    Farmington Hills, MI
    Bill Nichols
    Hi, I discovered at last years FCA judging that my 1998 550 was suppose to have a battery heat shield around the front and inboard side of the battery.
    I ordered the part and am about to install it when I realized, I wasn't sure if it is suppose to be a silver, raw metal finish, or painted black. I have looked at photos online in ads for cars and it appears it should be black but then then tech at the local dealer seemed to recall it as silver. I could not find a factory photo of this part.
    I would like this forum's input.
    Secondly, I presume it fits on top of the battery hold down strip that runs along the forward edge of the battery , as it uses the same nuts to hold it in place, can you confirm that to be the case and not that it fits under the retention bracket?
    Thanks,
    Bill
  2. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    It seen to be either stainless steel or some kind of chromed/plates finish, not black. I don’t remember how it is attached...
  3. Rifledriver
    37,100
    Early 550 had no heat shield. Later cars had polished stainless heat shield and 575 had fragile aluminized foam heat shield.
  4. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    When we installed an Interstate battery in our 575M, we did have to do some minor cutting and fitting of the foam shield with very satisfactory results.
  5. Rifledriver
    37,100
    I have in the past just wrapped it as well as possible and tape it off in the back.
  6. JimEakin
    JimEakin Formula Junior
    989
    Mountain Living
    Jim
    My 550 did not have a heat shield when I bought it. It now seems to be unobtainium. So I cut out a section of a Styrofoam cooler and inserted that piece between the battery and the overflow tank. (My C5 Corvette has a special enclosure around the battery to solve the same problem.)
  7. 308 GTB
    308 GTB F1 World Champ
    11,720
    New Jersey
    Barry Wolinsky
    Did you check with Ricambi America?
  8. JimEakin
    989
    Mountain Living
    Jim
    171903 angle bracket is unavailable. Could always make one. But then could make 178884, too. Also, the tie rods are $65 each.
    @Rifledriver 's proposal to wrap the battery makes sense.
  9. BillN
    BillN Karting
    144
    Bill Nichols
    Thanks for the feedback, my car is after the breakpoint, so I will install the shield unpainted.
