Battery Tender - Stupid Question | FerrariChat
Discussion in '360/430' started by cole328, Jun 1, 2019.
  1. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    Hey guys...when I took my F430 Spider in the other for some routine maintenance, I told my indy that I thought it was time to add a tender to the car(never had any issues, and drive the car weekly),as I wanted to avoid any issues going forward. Anyway, he's a great guy, and after addressing the minor issues, simply left a quality tender in the passenger seat.
    Sooo.. the question is, did these cars already come wired for the expectation of the tender (i.e., the wire was already installed in the passenger wheel well by the factory?) thx
    scott
  2. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    It has a provision but only for the stock Ferrari charger. You can just connect directly to the battery like I did.
  3. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    There is a connection for the Ferrari tender under the dash next to the glove box on the right
    Sent from my SM-T580 using Tapatalk
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    If you cannot get the special ferrari plug to connect to the installed socket, you can pick up the cables behind the seats- this will give you a cable sticking out you can connect to- a lot easier than connecting to the battery in the foot well
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    This is what I did. Works fine.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You can check your owners manual as it differs from year to year.
    Mine is a 2006 and it has an Amphenol connector in the trunk as battery charging port.
    It uses the old super big battery charger.
    The advantage to this method is you will see an indicator in your display that the battery is connected to the charger.
    On later year models there is a battery charging connector under the dashboard on the passenger side. So check your owners manual.
    On mine, the previous owner installed a CTEK Charger but I read stories here that the old CTEK chargers are unreliable so I purchased a new battery charger and it works great. My new NOCO battery charger came with a battery charging leads that hooks up directly to the battery terminals.
    The battery charging leads are tucked under the passenger side dashboard.
    Another option as others have mentioned is to install the battery charger cable leads right behind the driver seat for easier access / hook up & removal.
    Your option.
    Dan
    tboniello likes this.
  7. espvh
    espvh Formula Junior
    Nov 11, 2005
    553
    NEW YORK!
    whatheheck likes this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
  9. espvh
    Nov 11, 2005
    553
    NEW YORK!
    I don't know about that, I use the mus 4.3:
    "Once the battery is reconditioned it is ready for charging, and once fully charged can be kept plugged into the MUS 4.3 endlessly. CTEK’s unique “maintenance” will never, ever boil a battery — a distinct difference between CTEK and traditional trickle chargers. Leave a trickle charger on too long and you will destroy your battery; leave a CTEK on for a month and when you return your battery will be 100% charged, ready to go."
    https://www.gadgetreview.com/ctek-mus-4-3-test-charge-battery-maintenance-system
    Caeruleus11 likes this.
  10. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
    Caeruleus11, Need4Spd and whatheheck like this.
  11. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    161
    Indianapolis, IN
    I did it this way as well - very easy
    Need4Spd likes this.
  12. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    I posted parts details a show to make the cable in the 599 section.
  13. f355spider
    f355spider F1 World Champ
    18,044
    Or follow the thread on this forum and make your own: https://www.ferrarichat.com/forum/threads/yabtp-making-the-battery-conditioner-connected-light.347563/ I made my own to adapt to a Granite "Save a battery" battery tender.
    Or cut to the chase and go to Warren's website with all the same info: https://www.kumari.net/index.php/cars/ferrari-battery-charger-cable/diy
    Warren will also make and sell you one directly.
  14. AZDiverDLR
    AZDiverDLR Karting
    Sep 7, 2014
    92
    Tucson, AZ
    Dave Rowley
    +1 for the CTEK MUS 4.3. I used one on my F430 for four years and never had any battery issues. Same charger is now doing great job on my 458. Highly recommended.
    espvh and Caeruleus11 like this.
  15. azzurribaggio
    azzurribaggio Formula Junior
  16. f355spider
    18,044
    Tied to the ignition is a good thing, it prevents you from driving off with the cord connected. Cables are available from Warren, terminated to connect to the battery tender of your choice, or you can make your own, he gives you all the instructions, part numbers and sources. I made my own, very easy.
  17. oc23
    oc23 Formula Junior
    458
    Rob Yo
    Bumping an old thread from nearly 5 years ago. It seems these adapters are $60-90 now. I have a NOCO 1100 Genius but it seems there are better options. What are the best options these days and is there any that would plug directly in the plug other than the factory one? Thanks.
  18. f355spider
    18,044
    Make an adapter and save yourself from those prices. Only Ferrari sells chargers with the plug. There are a couple third parties that will sell you a cheapo private label charger/tender and include the appropriate adapter plug/cord, but there are better options.
    I use Battery Minder and Save a Battery.
    Compatible with all common battery types including lithium.
    https://www.batteryminders.com/batteryminder-model-128cec2-12v-2-4-8-amp-charger-maintainer-desulfator-lithium-charger-maintainer/
    Or Granite Digital Save a Battery: (works with everything but lithium)
    https://www.batterysaver.com/store/p78/2365-lcd.html
    If you shop aroud online, you can find them discounted from the list prices on various websites.
    Like here:
    https://www.batterystuff.com/battery-restoration/12-volt/
    oc23 likes this.
