Beechcraft Starship | Page 2 | FerrariChat
Beechcraft Starship
Discussion in 'Aviation Chat' started by rob lay, Nov 18, 2009.
  1. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #26 toggie, Nov 21, 2009
  2. donv
    donv Two Time F1 World Champ
    26,268
    Portland, Oregon
    Don
    I've often wondered if they used the Starship as a chase plane for White Knight in part because nothing else could go slow enough at 41,000. The indicated airspeed for White Knight up there was very low, as I recall.
    Or maybe it was just because it looked cool in pictures...
  3. alum04org
    alum04org F1 Rookie
    4,816
    Plymouth, MI
    Wow, just sad.... the disposition listed on so many of them.
    "Decommissioned, dismantled & destroyed"
    Must have been it at the Evergreen Museum in McMinnville, OR (a very worthy museum, BTW, as you all likely know the Spruce Goose now resides there, along w/a fine example of a Ford Tri-Motor + lots more!). Starship sitting outside.
    Thanks.
  4. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,887
    Edwardsville, IL
    Jeff Kennedy
    Actually, this makes sense. If there are operational aircraft then the manufacturer is mandated by the FAA to maintain airworthiness support. There is also legal liability as a concern for any manufacturer.
    Jeff
  5. severtecher
    severtecher Karting
    May 1, 2004
    62
    Tucson AZ USA
    Kevin Fox
    There used to be several at Avra Valley or MaranaAirpark AZ ,I can't recall which.
  6. Tcar
    Tcar F1 Rookie
    is probably the SpaceShip One chase plane. It's based in Aspen.
    http://www.bobscherer.com/Pages/Starships%20NC-51%20to%20NC-53.htm#NC-51
    A Starship flies over my office 3-4 times a WEEK! Based at Rocky Mountain Airport, Broomfield, CO - Stevens Aviation.
    Very distinctive sound, can't miss it.
    IMO, the FAA killed the Starship. No reason for all that weight.
  7. rajn72
    rajn72 Rookie
    Feb 11, 2004
    49
    The starships can fly RVSM - especially if the STC is installed. We routinely fly one RVSM. Grest speed, quiet, and good fuel burn at 36.0.
    Probably the best twin with comfort I have ever flown.
  8. th535is
    th535is Rookie
    Nov 17, 2009
    16
    Birmingham, AL
    #33 th535is, Mar 25, 2012
    There is one sitting on the side of the road behind a fence in the outdoor exhibit of the Southern Museum of Flight in Birmingham, AL. It along with a couple of other rare aircraft are just sitting outside decaying in the elements sadly.
    There is also a Lockheed A-12 (predecessor to SR-71) sitting out there as well. I unfortunately don't have a good picture of it though. (Actually I just found one on their website.)
    NürScud likes this.
  9. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    Back In the 90's when I was flying out of North Las Vegas, I use to frequently see two of them parked together on he paddock. I always loved the Starship. When they were there, it was like an event. The whole airport was a buzz. I remember walking from the flight school I was taking lessons from all the way over to the other side of the airport just to look at them...and we were not the only ones who were just gathered around looking at them.
    Mark
  10. Tcar
    Tcar F1 Rookie
    It was because they are both Rutan designed...
  11. tritone
    tritone F1 Veteran
    7,217
    On the Rock
    James
    #36 tritone, Mar 25, 2012
  12. docmirror
    docmirror Formula Junior
    May 6, 2004
    781
    Ft Worth TX
    ^^This^^. If the plane had been built on the structure that Burt and Scaled designed, it would have met the weight, drag, and performance goals(pretty close). The FAA required many, many different re-works of basic structure like the spar carry through.
    The Beech Starship has the enviable record of ZERO accidents or incidents in the NTSB database. Not that the King air isn't a good plane, but the Starship was the right design, but the FAA screwed it all up. The Piaggio is proof of the concept.
  13. rajn72
    rajn72 Rookie
    Feb 11, 2004
    49
    #38 rajn72, Apr 2, 2012
    NürScud likes this.
  14. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    Zero accidents because there are like 5 of them. Probably less.
    Beech screwed the pooch designing the Starship. They should've spent that time and money building a SE Turboprop. Instead, they let Socata and Pilatus take that spot and sell thousands of airplanes and are essentially putting Beech out of business.
  15. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    You must know the description of an elephant. A MOUSE BUILT TO FAA SPECIFICATIONS.
  16. Gatorrari
    Gatorrari F1 World Champ
    16,505
    Georgia
    Jim Pernikoff
    Or that of a camel. A HORSE DESIGNED BY A COMMITTEE.
  17. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I have a book that claims the FAA screwed up the Starship design because one or more of the regulators was scared to death by the old BOAC Comet inflight structural breakups and just kept insisting on structural changes that added more and more weight.
    In other words - it was not just the lightning strike issue - FAA talked themselves into fear of the composite structure itself.
  18. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Just mentioning that i have sighted a starship twice over the last weeks, both times at low altitude, southbound and my guess on final approach into Westchester airport (i live not far away).
    A very particular high pitched engine sound and they look great (imho). Its probably the same aircraft.
  19. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    You sure it wasn't an Avanti Piaggio? Similar design. Same sound. I live near Long Beach airport in CA, and see them on a regular basis.
    I believe I saw a few Starships in Pinal Airpark a few months ago. (not flying)
  20. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    In 1993 I saw a Starship in Sandpoint Idaho that flew in with an obvious well healed group that met another well healed couple in an Albatross and then a Mallard came in with some of the same. That's the only Starship that I have ever seen. Quite an airplane and noisy.
  21. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    Last month I was flying SFO to ATL and heard a Starship call sign, didn't see the plane though so no really sure it was an actuall Starship or not.
  22. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,613
    AZ
    Rick
    One of the coolest aircraft ever. I've seen one frequenting KSNA lately. Apparently a few owners told Beech to pound sand when they asked for them back.
  23. Tcar
    Tcar F1 Rookie
    I see a Starship pretty regularly; there's one based at Rocky Mountain Airport.
    Actually heard it fly over yesterday evening but didn't get outside in time to spot it.
    There's often an Avanti Piaggio at Centenial also, but I have never seen it fly.
    Wonder if they are noisy inside? Anyone know?
    Read somewhere that the sound is from the props 'chopping' the engines' sound sine wave.
    Maybe that's why the B-36 was so unbelievably loud. They used to land over our house int ABQ when I was a kid. Pictures fell off walls, etc.
  24. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    Pretty sure not, pretty low altitude as they swing over my place.
  25. Tcar
    Tcar F1 Rookie
    #50 Tcar, May 29, 2013
    Starship just now flew over heading about 350, about a minute ago.
    Headed for Rocky Mountain Metropolitan Airport, Broomfield, CO (KBJC).
