Belt Change - Gas Tank | FerrariChat
Discussion in '348/355' started by bballto, May 18, 2019.
  1. bballto
    bballto Karting
    Mar 10, 2014
    155
    Anybody change the belt via gas tank removal. Thoughts?
  2. Qavion
    Qavion F1 World Champ
    14,317
    Ian Riddell
    Some of those links are for the 348 and the owners had plenty of advice.
  3. Jh348
    Jh348 Karting
    Sep 5, 2015
    187
    Finland
    Jesse Heinola
    steved033 and Qavion like this.
  4. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,574
    San Carlos, CA
    Mitchell Le
    There have been multiple threads and discussions on engine out vs engine in belt service. There are pluses and minuses both ways. My personal 355 Berlinetta just got its engine out this week and it's back in. I am waiting for a couple of small parts before I can fire up the engine. It does not have any deferred maintenance so there was not a lot while-in-there to do. Just engine out, belts swapped, cam timing, no valve adjustment, gaskets changed, filter changed, and back in the car.
    The 348 is slightly different in that it needs valves adjusted. If there are more than a couple of valves, it may be easier to remove the cam shafts and change the shims out that way.
    Its water pump is used as an idle bearing for the single timing belt so its important to service that preemptively.
    To get maximum power of the engine, you want the camshafts to be timed perfectly and that requires degreeing the cams to 1 degree of specs.
    All those things are much easier with the engine out of the car than with it in the car. The 12 inch space you get by removing the gas tank is not a lot of space to work in.
    I understand the argument of not wanting to remove the engine without a lift, but many here have done just that with just jack stands. I come from Porsche 911 world and Porsche owners prefer to remove the engine without a lift.
    Your car and your choice to make. It's all good
  6. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,319
    Southern New Jersey Shore
    Phil
    Having done 308 "engine-in" belt services myself, in my opinion engine-out is preferable from a QC point of view. You can't compare quality when half the service is being done in the dark or blind by feeling around instead of right in front of you on a bench in the light. And for the OCD crowd, there are therapeutic aspects of being able to clean your engine and engine bay properly when it's out.
  7. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    #9 Cauf61, May 19, 2019
    As 2 newbies we took the engine out in 6 hours with mini lift. Kind a lot of work but basic very easy !
    Just be very careful for the balance of the 348 on these mini lifts !!! Alway's use extra support on the back end.
    flat_plane_eddie and Wade like this.
  8. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
  9. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    flat_plane_eddie likes this.
  10. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
  11. yelcab
    Nov 29, 2001
    13,574
    San Carlos, CA
    Mitchell Le
    348steve likes this.
  12. Qavion
    14,317
    Ian Riddell
    Some folks put large water bottles in the front luggage compartment to stop the car tipping.
  13. INRange
    INRange F1 World Champ
    12,567
    Virginia/Florida/Caymans
    JD
    I would be worried that would cause a new problem once the engine came out and the weight was off the back end of the car.
  14. Qavion
    14,317
    Ian Riddell
    Not sure. The normal (engine fitted) centre of gravity is very close to the rear jacking points on the car. I was thinking that the water bottles would be sufficient to stop tipping, but impossible to tip the car the other way even with the engine out.
  15. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Engine was designed to come out for a reason...but to each his own
  16. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Correct I also tied a 20 liter water tank to the front wheel. Because the car is so far backward ( on the mini lift) it is literally balancing on the rear points. You can tip it over with one hand easily ! As i found out. With the engine out it is solid as a rock. No problem.
  17. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,079
    Atlanta, GA
    Steve D.
    It's 16 bolts and a few hoses. Hondas are tougher.
    sjd
    kenneyd, Cauf61 and baschul like this.
  18. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Does the 348 have 16? The 355 has 18.
  19. steved033
    Apr 12, 2017
    10,079
    Atlanta, GA
    Steve D.
    6-6 front 2 and 2 in back
    sjd
  20. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    #22 Jackie and bill, May 20, 2019
    6-6 in the front, 2 under each wheel arch (4), and two at the back.=18
  21. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    How different is the 348 unit in comparison?
  22. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,021
    NE FL
    Ken
    I ran into the opposite problem I 355, while trying to get one of the radiators. I liftef the back of the car off the lift an incursiones or two and had to pull it back down, nearly gave me a heart attack. I would not put any weight in the front at all
    Qavion likes this.
  23. steved033
    Apr 12, 2017
    10,079
    Atlanta, GA
    Steve D.
    The strut towers stay with the car.
    So i suppose I should count 8 more as you have to undo the 4 nuts on the top of each strut tower.
    sjd
