Better brakes for the Countach | FerrariChat
Discussion in 'LamborghiniChat.com' started by Chadbourn Bolles, May 5, 2018.
  1. Chadbourn Bolles
    Chadbourn Bolles Formula Junior BANNED
    Aug 5, 2005
    820
    Leesville, SC USA
    Chadbourn Bolles
    I have been asked by several Countach owners to come up with a brake kit. Therefore, using the Wilwood parts, for around $2300.00 you can get parts from Wilwood and with a few small mods, everything would be a BOLT on, no adapters.
    If you want to use your original rotors, the price would be around $1100.00 for a bolt on system. The system is matched to your original brake master cylinder, and brake bias stays the same.
    I can provide to anyone that wants them, the Wilwood part numbers and you can contact Wilwood and get them.
    Just using the calipers alone you would loose around 40 lb off of the car and have a much better brake system, and it is a bolt on, no adapters to mess with. Then if you want to use the Wilwood rotors you would loose around 80 lb off of the car.
    See the pic, the one showing the stock ATE, caliper and rotor, then the one showing the Wilwood set up.
    There is about a 25 lb difference between each front wheel using the Wilwood setup, for a total +/- of 80 lb for the whole car.
    Peter K. likes this.
  2. wbaeumer
    wbaeumer F1 Veteran Consultant
    Mar 4, 2005
    8,988
    When I owned my LP400 I became aware very quickly that the brakes are not up to its speed. When the car was later (in 2000) in the UK with Steve Hart for an engine overhaul, it received racing brake pads. From that day on the brake efficiency became 60% better than before.
    I am sure you can get better brake pads today for a far better result than 18 years ago.
  3. EarlyCat
    EarlyCat Moderator Moderator
    Mar 9, 2005
    9,999
    Shot gun shack n another prt of the World GS KW KY
    Interesting. Spill the beans and share the part numbers!
  4. Peter K.
    Peter K. F1 Rookie Silver Subscribed
    Jan 9, 2004
    4,448
    Connecticut
    Peter K.
    Oh thank god we're addressing this finally! We all have been talking about this since the old Ltalk and Lpower days.
    Put me down for calipers and rotors part numbers. Been on my mind for YEARS.
  5. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,350
    USA/France
    Chad, you are not mentioning the pads. In the past we heard EBC had good pads like redstuff or yellowstuff, dont quite recall. What pads are you using?
    i can see a way for people to get better brakes and restore/save the originals.
    Also are all the caliper/rotors the same across all CT models? I dont quite remember from the top of my head.
  6. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    EBC Redstuff are a direct fit for the original calipers and a huge improvement.
  7. Peter K.
    Jan 9, 2004
    4,448
    Connecticut
    Peter K.
    I have been running the Redstuff for years now on the Countach. I do not know if others running them have the same problem but they seem to need a lot of heat to stop really good.
    Before this thread I was going back to a regular semi-met pad, like I did with my Urraco. That car's braking improved quite a bit when I tossed out the Reds that were in there.
    I used to race bikes in the 90's and only used EBC pads and they were the best for high speed stuff.
  8. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,925
    Florida
    Ken Roberson
    I am planning on doing this.. working on a few more questions and then can move forward. Planning on using the pads that Wilwood recommends for the calipers
  9. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    how is wheel clearance with rotors and calipers?
  10. Chadbourn Bolles
    Aug 5, 2005
    820
    Leesville, SC USA
    Chadbourn Bolles
    Not a problem.
  11. staatsof
    staatsof Nine Time F1 World Champ Silver Subscribed
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Aren't the original fronts just the ATE 4 piston calipers utilized by BMW on some of their sedans in the mid 1970s to early 1980s?
    Yeah those are pretty heavy, all cast iron. But cheap to repair once you know that! :) Used on Urracos as well right?
    I'm sort of surprised that Wilwood has a direct bolt on caliper?
    Bob S.
  12. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Try switching to the yellowstuff. I've heard good things and I'm about to put them on one of my cars soon. EBC pads now come with a scrub in coating to clean up your rotors while bedding the pads. I hope it works!
  13. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,061
    Switzerland
    Raymond S.
    Yellow stuff need heat to work appropriately, red stuff is much better for road use.
  14. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Everything I've heard and read is just the opposite of that. I used to have greenstuff on this car which was OK at the track but I got a lot of build up on the rotors.
  15. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,925
    Florida
    Ken Roberson
    Yes..the originals are just off the bmw 7's from the day.. but if they are due for a rebuild then why bother rebuilding junk.. one common complaint for decades now has been this cars brakes... as in, lack of.
  16. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Originality?
    Those calipers are heavy but just fine on other cars (my interest) but not up to snuff for a car this powerful and fast if you're going to really drive it. And yet ... Valentino managed somehow ... lol :D
  17. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,925
    Florida
    Ken Roberson
    VB knows better than to criticize a countach
  18. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Certainly his bank account does ... :p
  19. ken qv
    ken qv Formula 3
    Oct 25, 2006
    1,925
    Florida
    Ken Roberson
    and i due like and appreciate originality, but my car happens to be a driving, used car which already has modifications (bigger aluminum radiators, electronic ignition, kevlar clutch etc) if it were all original then i would certainly just rebuild the current calipers.
  20. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    Oh I understand. I'm not an originality zealot except for really obvious visual stuff, Pantera style ...
    I presume that Chad's solution includes greater pad area and perhaps increased clamp load? So this is is a F&R solution i.e. 4 calipers total?
    That might be rougher duty on original rotors? I p[resume thoise rotors are now very expensive? So maybe the rotor upgrade is the cheaper solution if you drive hard and drive a lot?
  21. slownrusty
    slownrusty Formula Junior
    Oct 1, 2014
    395
    Houston
    Slow Rusty
    Nice upgrade!
    I did the Brembo upgrade on my '91 Diablo (front and rear) and its nice to have the braking confidence to match the car's acceleration and speed.
  22. Peter K.
    Jan 9, 2004
    4,448
    Connecticut
    Peter K.
    Originality.......less important when it comes to bolt, then bolt off, safety mods. Unimportant unless you are about to sell it or Pebble Beach it :) Then you can bolt the original stuff back on.
  23. Chadbourn Bolles
    Aug 5, 2005
    820
    Leesville, SC USA
    Chadbourn Bolles
    Bob S.
    Actually Bob, they don't just bolt on like that. The mounting hole is too small for the Lamborghini mount bolt, something like 11.5 mm where the Lamborghini is 12 mm. No big deal, easy to enlarge that hole. Next the brake line hook up is in US spec, so you have to adapt that, again not a big deal.
  24. 87-Countach
    87-Countach Karting
    Oct 12, 2004
    222
    Dallas, Texas
    Richard
    I think there are a few of us who would appreciate the information regarding the Wilwood calipers and rotors. Myself included.
  25. staatsof
    Mar 13, 2005
    95,954
    Fuggetaboutitland
    Bob
    I beleive his offer is to sell them to you at the above pricing which frankly seems quite reasonable and if I'm wrong about that then I'm sure Chad will clarify this shortly.
