Better brakes for the Countach | Page 3 | FerrariChat
Discussion in 'LamborghiniChat.com' started by Chadbourn Bolles, May 5, 2018.
  1. staatsof
    96,382
    Fuggetaboutitland
    Bob
    Yeah Lamborghini didn't beleive in vacuum pump assist for the braking system even though with all of that enormous intake capacity there is often scant vacuum build up available after a long hard braking situation followed by enormous acceleration hence no vacuum and then a need for a lot of brakes again. That's not typical road conditions but very typical track conditions. Some people have added them to their cars though that of course violates originality guidelines ... :p.
    First bite can be a function of both the type of pad and the amount of boost available. Clearly you can easily do something about changing the style of pads. Making sure the brake booster and vacuum system is up to snuff or BETTER with an assist pump will also help. Some Espada guys have added used ones from a much later Audi as an example. Perhaps that can be well hidden on a Countach? I didn't know that the early TRs also used these apparently ubiquitous ATE calipers. Do they have the same piston dimensions?
  2. staatsof
    96,382
    Fuggetaboutitland
    Bob
    Joe, if you're going quote me to buttress your point please include the entire quote in it's context. :)
    Carbon fiber rotors and floating racing calipers would of course be enormous improvements but might butcher the car's potential for originality in the process.
    Hard for me to imagine very many people now driving something as old as a Countach in ways that require that sort of a setup. But lots of guys used to do stuff like that years ago and go speeding in Nevada! :D
    I know one guy who actually drove a heavily modified QPIII and tried to keep up on one of those "outings" ! An aerodynamic brick trying to achieve 190 MPH. Plenty were nuts back then! Different age ...
  3. rmolke85
    rmolke85 Formula Junior
    Mar 11, 2013
    760
    #53 rmolke85, May 13, 2018
    A fully sorted system with some redstuff, and ATE Gold fluid really should be enough of a modern upgrade from period to feel a large difference. Not to mention now we can get modern rubber on original spec tires for our rims. No one mentions why the Pzero never fit, but the Anny wheeels are much different than the old OZ wheels..... Flawed day one.
    The trick to make it all hang together is to do a perfect bedding in process of brakes. Is you spend the time to do it right, the difference in performance would be really noticeable to one that was just driven normally day one. Can’t stress that enough either.
    And my next question would be do the new rotors employ modern metal composite? I would assume so. If that’s the case, then we’re really cooking with gas.
    Lastly anyone out there make stainless braided lines? Last piece that would really help with pedal feel.
    Just go get your brakes rebuilt and get new tires.
  4. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    The Countach QV Downdraft used by Steve Cropley in the CAR magazine test versus the Testarossa was a 1985 model year car, the brakes are same as LP500S.
    I don't have pre and after 1987 pedal assembly images, sorry.
    I'll be sure to do that.
    This
  5. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    The mount for the brake pedal is the same for the 5000S thru the 25th car. The pedal for the 5000S is 4213615 The pedal for the 87 QV car is 4225164, the pedal for the 25th car is 4228350. Those are the differences. Now for the clutch, from the 5000S thru the 25th car the pedal mount is the same. The clutch pedal for the 5000S is 4213616, the pedal for the 87 QV car is 4225163, the pedal for the 25th car is 4228348.
  6. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,388
    USA/France
    I just noticed we never got the wildwood part # in this thread. :(
    Interesting debate instead but honestly, in 2025, I will shoot for real brakes with full retro install of OEM possible. The "80s brake feel" of a countach on 2025 roads will get you killed unless you drive it like an old lady.
    EarlyCat likes this.
  7. I did upgrade to Wildwood on my Pantera. I'll have to look, probably the same calipers. Big improvement fwiw.
  8. Peter K.
    Peter K. F1 Rookie
    4,454
    Connecticut
    Peter K.
    EarlyCat and peterp like this.
  9. Sp1der71
    Sp1der71 Karting
    Jan 18, 2019
    118
    Simon Ashley
    Spyder-Man, Peter K. and EarlyCat like this.
  10. Countachqv
    Apr 25, 2007
    2,388
    USA/France
    do the HiSpec come with a mount kit or did you make one?
  11. Sp1der71
    Sp1der71 Karting
    Jan 18, 2019
    118
    Simon Ashley
  12. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,234
    Patrick - if you still have the original brakes on your car, I suggest you restore the parts and have them reinstalled. Your car is a special piece of automotive history. As time goes on, maintaining the original components on it will become more and more valuable. As for the general notion that original Countach brakes are unsafe, I would suggest when maintained and operating in proper condition they are more than sufficient. I had my brakes restored and I’m very proud of how they perform. I’m happy to discuss if you like.
  13. Peter K.
    Peter K. F1 Rookie
    4,454
    Connecticut
    Peter K.
    I do not. I'm not the one who put the kit together
  14. IIRC the calipers are BMW.
  15. Countachqv
    Apr 25, 2007
    2,388
    USA/France
    Jeff, I undestand your point. However on the front brake I am leaning better breaks. I will not go into details here as far as how I end up not trusting them on the road but I compare them to my Aston and Porsche with my same habbits and I am looking for that kind of brakes. The brembo feel. My oem can be restored and put away to be remounted anytime.
    If I change up, I want to make sure all OEM goes with the car and can be reinstalled. That is certainly non negotiable for me. All my car components appears OEM.
    I'll give you a call to talk. Started with a clutch and now the stuff creeps once the engine is out because I just cant help myself I guess..
  16. Countachqv
    Apr 25, 2007
    2,388
    USA/France
    Simon, do you have the kit part for the hi spec Monster or a specific contact? The company sees hard to get in touch with thks
  17. Sp1der71
    Sp1der71 Karting
    Jan 18, 2019
    118
    Simon Ashley
    Will have a look as it will be in an old e mail
  18. Peter K.
    Peter K. F1 Rookie
    4,454
    Connecticut
    Peter K.
    Couple of time the OEM brakes faded on exit ramps from 75mph.
    Upgrading is no big deal for originality because you can rebuild the originals and set aside for future installation. Same with shocks
  19. I would be interested as well.
  20. Sp1der71
    Sp1der71 Karting
    Jan 18, 2019
    118
    Simon Ashley
  21. dinonz308
    dinonz308 Formula Junior
    Nov 26, 2017
    869
    Dean
  22. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,213
    MO
    Omar
    #74 Auraraptor, Sep 23, 2025
    Neutral party (don't have a Countach but I have gone through this same thing with all my Ferraris but ironically not my diablo)
    You can get 80-90% the improvement by simply refreshing the factory system (pads/flush, rebuild if sticking or leaking) and proper new modern rubber. The later is often under appreciated as people wonder why tires date coded in the Bush administration dont work as well.....
    islerodreaming likes this.
  23. Countachqv
    Apr 25, 2007
    2,388
    USA/France
    thanks. Helpful info! looks like bolt on. May likely go this route if no drills needed. I can rebuilt and save my original ones. looking into it
    I read much of the thread and I get the 80s feel and need to adjust driving habbits. That is exactly my issue along with brakes being getting older.
    But once you tasted the modern braking, there is no going back for me. I enjoy cars more with confident braking and If I dont like it anymore, I just can re-install the rebuilt BMW anytime I want being all bolt on.
    That is exactly what I am doing with the shocks. I will get adjustable bolt ons made for the countach. I'll get picts next months. The restoration is just growing exponential.
