Anyone have the bolt sizes type and length used inside the 360? For example The interior aluminum trim pieces The trunk bolts holding the engine panels? Thank you!
I don’t recall, but you can get them here. I had to get some because a prior owner or tech had stripped the hex head on a few of them. https://www.mcmaster.com/hex-drive-stainless-steel-socket-head-cap-screws If no one can respond with the answer, just unscrew one and test it at the local hardware store’s bolt gauge, or just get your own gauge online. Sent from my iPad using FerrariChat
Engine bay cover panels right and left 5mm by 20mm long there 16 of them maybe 18. Most every thing else is m6-1.00 for heat shields wheel wells, stuff like suspension m8-1.25, online Amazon you can buy measuring tool for around 30.00 helps out allot wend replacing fasteners. I have decided to replace every single bolt with Titanium fasteners one of the best upgrades period !! Love the look and saving weight ! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
