Boosting AC on 512M | FerrariChat
Boosting AC on 512M
Discussion in 'Technical Q&A' started by WILLIAM H, Aug 1, 2005.
  1. WILLIAM H
    WILLIAM H Three Time F1 World Champ
    Nov 1, 2003
    35,532
    Victory Circle
    HUBBSTER
    Its friggin Hot in Miami, I mean really friggin HOT !!!!!!!!!
    From 11:30 until 7:30 you dont want to be outdoors. Is there anything I can do to boost the performance of my AC or replace it w a better AC ? Thanks
  2. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    You could drive a Toyota when it's hot, AC is good in them!
  3. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Many have tried, I believe all/most have failed.
  4. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    Get one of them in car fridges that plug in the *** lighter and leave the door open on it all the time ??????????????????????
  5. retired
    retired Formula Junior
    Jul 30, 2004
    286
    The problem with most Ferrari A/C units is that we drive the cars to slow. The belt pulley is set up for a high RPM motor (slower compressor speed ot low engine RPMs).
    The faster you go, the better it works. The fix is a larger pulley to drive the compressor faster at low speed (have done this on 400i). The problem, if you run the RPM up to high, the compressor will be very unhappy.
    I do not know the uper limit RPM limit on the compressors. Maybe someone here knows.
    Solution, set the car up for hot weather driving and "put 2x4 under your gas pedal" !!!
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Hey Whilliam have you had the freon level checked. You could be low and need the system recharged.
    Try doing a seach in the old archives. I remember seeing a DIY thread on A/C a while back. Also if you are still using the R12, this may be the time to switch over to R134
  7. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
  8. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I think the compressor can make enough coolth but the problem seems to be the blower speed with most ferraris. Especially your car with no top available you will need to blow alot of air across the evaporator to get a cool feeling. I think there must be some alernative brand blower housing that could be fitted to the car. I would check with Tim Stnaford and see if he has any ideas. They fixed the A/C in my 348 a few months back and it keeps me plenty cool now in Palm Beach. I have read that the recirc. flap may get stuck and reduce the amount of air flow for the system also.
    BT
  9. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,891
    Dallas, TX
    Jim E
    If you want to keep your car cool in Miami in the summer, do NOT drive a convertible! Is this rocket science?
