News
Boxer cabin vent hole size and spacing
Discussion in 'Boxers/TR/M' started by mexicruiser, Jul 20, 2020.
  1. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    72
    Hello, would someone be so kind to measure the hole size and approximate spacing of the group of small vent holes in the rear of the cabin? I’m recovering the leather of this part and can’t use the old one as a basis because it has already been recovered in the past and it is not close to the original.
    While in storage I left the door glass 5cm open, a rat jumped In (I could see the footprints on the door) and couldn’t get back out, it gnawed at the leather in this area because I guess it could feel the fresh air. The rat died on the passenger floor carpet and luckily didn’t do more damage than this (and of course making me remove and deep clean everything else).
  2. Newman
    Newman F1 World Champ
    Professional Ferrari Technician Owner Consultant
    Dec 26, 2001
    13,549
    Canada
    Newman
    The first step is to close your eyes, then start punching holes. I swear thats how Ferrari did it.
    mexicruiser and turbo-joe like this.
  3. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    72
    Thank you very much Ludwig, so holes are close to 1/8” and I do see a triangle like pattern, will try to replicate it. Does that tape have two different inch scales? Continental?
  4. willrace
    willrace F1 World Champ
    Rossa Subscribed Owner
    Oct 21, 2006
    19,508
    North Tay-has
    Kurt
    We (my upholsterer, actually) replicated it by using one side as a pattern to mark a card (through the holes), then punching those out. using the pattern card, marked each hole on the leather with wax, and punched them individually.
    The hard part is keeping the orientation correct, so they are not only in the correct locations, but not tilted differently vs. the opposite side.
    Ferrari would have used a pattern punch to do it all in one shot, but they were making more than one.
  5. Ludwig
    Ludwig Formula Junior
    304
    Redmond WA
    Ludwig Allegra
    I places the 1" side closest. The other scale is in 1/10 ft
    mexicruiser likes this.
  6. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    72
    Willrace, the holes are no longer original so I can’t use those as a sample, but the idea of making a template is a good one, that way I can be more precise.
  7. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    6,270
    southwest germany
    romano schwabel
    this template then you just can use for both sides, just turn it outside inside
  8. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    72
    turbo-joe likes this.
  9. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    6,538
    So. Cal
    Armen
    My Suitcase Guides were riveted. I just replaced them last week.
  10. mexicruiser
    mexicruiser Karting
    Aug 28, 2012
    72
    Thank you ag512bbi, I’ll source some long pop rivets for that, PO recarpeted the car and I find screws on some locations and rivets on others, I’m guessing there should be only rivets? I found screws in the following places: accel plastic pedal cover, rocker panel covers under the ashtrays, center tunnel covers.
  11. Ludwig
    304
    Redmond WA
    Ludwig Allegra
    Yes Ferrari is very fond of rivits
