This is a pair of 355 seats we are repairing and converting to Daytona pattern. Image Unavailable, Please Login Image Unavailable, Please Login
The drivers bolster foam padding is shifted over exposing the metal frame. Image Unavailable, Please Login
We found the leg bolster came off it's track and was pushing the foam over on the drivers side bolster. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Seat disassembly. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Pattern work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Pattern and trimming. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sewing and fitting backrest covers. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
More trimming. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Covers fitted on the other seat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
We had to change the foam cushion shape secure the daytona pattern from the back avoid a loose fitting cover. Image Unavailable, Please Login
Tooling was made to emboss Cavillino replicas into the headrest. I love how this came out. Image Unavailable, Please Login
Sewing the actual insert. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Building up foam on a worn out bolster and fitting cover. Image Unavailable, Please Login Image Unavailable, Please Login
Sewing Daytona inserts. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
We changed the hole pattern to 3 in each strip all the way down. The hole diameter was increased also. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
