Bradan 360 clutch service | FerrariChat
Discussion in '360/430' started by BRADAN, Jun 14, 2018.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,696
    Central NJ
    Dominick
    Similar to my other post ..what readings were recorded in the SD tool ... Can you give us printouts of when you use the tool before during and after that be great not sure if possible
    Sent from my Moto G (4) using Tapatalk
  3. RedNeck
    RedNeck F1 World Champ
    10,033
    The CSA
    Me
    Looks like this may be a 6 speed, so no clutch life readouts...
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,696
    Central NJ
    Dominick
    Thanks for pointing that out ..didn't look closely at pics
    BRADAN likes this.
  5. 24000rpm
    24000rpm F1 Rookie
    for a 6 speed, that clutch doesn't look like smoked. what's the symptoms?
  6. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    Like open heart surgery, I cringe seeing it all opened up like this, yet so very fascinating :)
    BRADAN likes this.
  7. 67bmer
    67bmer Formula 3
    1,231
    MD
    looks like the rivet at 9 o:clock just started to get worn - if that is the case, certainly not much life left...
    BRADAN likes this.
  8. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Its worn down to the rivets and the sideways cuts are fully gone, f1 cars normally slip before they look like this. It would lock out of gear and slip in high rpm.
  9. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  13. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Gr430 likes this.
  14. 24000rpm
    24000rpm F1 Rookie
    I have a few questions that have confused me for a while , I am not sure if this is the right thread to ask , but i'll try. These questions are for everyone who can shed some insight
    1. As we know the TCU will tell the percentage of the clutch used. And I understand that it is a rough figure and can be played by changing the "closed clutch position. Assume that from the new clutch installed, the TCU was calibrated correctly, what will be the actual (physical) thickness of the clutch if it were to display 100% used ( 0% left).
    2. when you resurface the flywheel, any special machining tool used since the surface is tapered.
    3. in a perfect world, and assume all labor costs = 0. If I want to maximize the usage of flywheel , clutch disk, pressure plate. Assume normal usage of the car, what would you expect the ratio of life expectancies of these 3 parts? what i mean is that, for every clutch used to bare 0% left, is the pressure plate still having life left? if so, what percentage roughly. In other words, how many clutches replaced until a pressure plate HAS TO BE replaced ( no good no more). Same question for flywheel life, how many clutches replaced until a flywheel HAS TO BE replaced. Of course, I understand these varies according to usage, and I understand this is a guesswork, but whats your opinion on this?
  15. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    1. Its a manual car so I cannot check wear percentage with the computer. On F1 cars I start seeing them slip at 50% or less but normally the throw out bearing fails before it needs a clutch. Always replace the OEM bearing with a Hill engineering bearing to avoid premature failure.
    2. Yes its a specific lathe for resurfacing flywheels and we balance the flywheel/clutch together.
    3. Pressure plate and clutch are replaced together never replace just the clutch disc. I have only surfaced a flywheel 2x now and would replace it on the 3rd it depends how badly burnt up it is.
    Every car and condition is different so you just use your best judgement based off what is actually in front of you at the time.
  16. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  17. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  18. tazandjan
    38,087
    Dan- Are you going to put an HE piece inside of that one?
  19. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    It already has it.
  20. BRADAN
    22,661
    West Babylon, NY
    BRADAN
