This is a 95 F355 with 14k miles that has not ran in 2 years. The belts have never been replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Engine dropped. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Upon inspecting the belt's condition, I was very happy we did not try to start the car beforehand. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
This dust all over the engine is header packing blown out from typical damaged exhaust manifolds. They will be replaced. Image Unavailable, Please Login
Valve covers removed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumpers removed for repair and repaint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bradan braided brake lines installed. Image Unavailable, Please Login Image Unavailable, Please Login
Interior plastic trim removed to be refinished. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Damaged wheel finish will be repaired and repainted. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Dry rotted tires will be replaced with Michelin Pilot Super Sport. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The clutch is worn out and will be replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Timing belts, cam seals, cam o-rings, tensioner bearings replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Cleaning engine block and installing headers. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Timing belt covers and water pump installed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
All belts installed and ready to drop back in. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
This burnt brake pad sensor wire opened a can of worms. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
It was followed under the dash and into the chassis harness. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
On a brighter note.... sticky no more did an excellent job on the interior pieces. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
