Bradan F355 valve job/major service | Page 3 | FerrariChat
Discussion in '348/355' started by BRADAN, Oct 4, 2016.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #54 BRADAN, Oct 26, 2016
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #55 BRADAN, Oct 26, 2016
  6. F355Bob
    F355Bob Formula 3
    I'm going through a major now. Why do you weld the timing gears?
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Bob,
    I've seen this done many times and when I was cleaning up my pulleys - I looked them over and the fence crimp is so tight and over the entire perimeter so I did not see a reason to do it.
    But, it takes a few seconds to do so I will probably do it anyway.
    If you wish to ship me yours, I can do it for you as I have TIG. It will take under 5 minutes.
  8. PAP 348
    Dec 10, 2005
    100,205
    Mount Isa, Australia
    Pap
    Cheers Dave, yes. :D
    My old boss would have killed me if I had a box full of valves like this.
    When we used to build race engines for customers when I was doing my apprenticeship 20 years ago, we took GREAT care with the valves.
    Whether we were doing a standard rebuild or building a race engine, my boss had a plastic 'jig' to sit the valves in so they would not get damaged.
    It was to protect the valve seat face from being damaged after it was cut and to also stop them being bent. As strong as they are, it doesn't take much to bend them which would cause them to stick and/or cause premature guide wear.
    We used to get brand new valves that were bent straight out of the box. We assumed it was dropped when being packaged and just popped back into the box without telling anyone.
    We would check every brand new valve for run out before fitting and re-check every valve we had returned to us from the machine shop. We had a few from those guys also. Must have been dropped.
    And when I say bent, I don't mean bent like when the timing belt snaps and bends them like bananas. lol
    They are bent, but you can't see that they are bent to the naked eye.
    Watch this video, this is how we used check them using a very similar v-block and dial indicator setup.
    [ame]http://www.youtube.com/watch?v=zSt0GpiYZ4A[/ame]
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,194
    CT
    John Kreskovsky
    What do you do to rebuild the lifters? When the major was done on my car the lifters were sent to Ferrari for rebuilding. Well, actually exchanged for rebuilt ones.
  10. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    John, is your project of making new guides still continuing?
  11. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,793
    Atlanta
    John!
    That project is on hold since the factory wanting to do it is insisting on my producing at least 10,000 of each. Sintered metal components are incredibly cheap to manufacture, but the tooling costs gets you big time. For a sintered component a run of even 10k is really low so I should be thankful I found a place to do even that. What I think I'm going to do is make something else with this factory and roll the guides in as part of the deal. Will keep everyone posted.
    Sorry, didn't want to hijack! This is a great thread. Thanks for posting your work. Always enjoyable.
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Will all due respect to all, manganese bronze are a great choice and no sinter tooling cost and easier on install and post install machining. And, plenty of places to get manganese bronze made in the USA verse overseas manufacturing.
  13. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Dan, what is your opinion on the guides, sintered steel or manganese for these cars?
  14. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    Thanks for the reply John.
    Again, it is a great thread.:)
  15. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    924
    Europa
    Bob
    I'm sitting here smiling at these comments about a few valves in a box... you guys do realise that the valves are hammering away in the head up to 70 times per second, while heated to >1,000C... What the heck is going to happen to some valves laid in a box? Or should they be laid on a silk pillow and hand delivered by an angel or something? :D:D:D
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, that is true with exception to the valve stem sliding in a guide and the valve closing against a seat and not edges getting nicked up :)
    Just a bit of a difference ;)
  17. spaghetti_jet
    Jan 5, 2005
    924
    Europa
    Bob
    Much ado about nothing.
  18. WATSON
    23,572
    WI
    +1 I would like to hear your opinion Dan. You guys have seen way more real world cars than most of us around here. Your expertise on the matter would carry a lot of weight. Thoughts?
  19. johnk...
    Jun 11, 2004
    11,194
    CT
    John Kreskovsky
  20. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    610 hp turbo 348.........nice :)
  21. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    You simply check by pressing on the lifter with the camshaft removed. A good lifter is rock solid, a lifter in need of rebuilding will easily depress.
    The downtime was killing us waiting for lifters to come back from being rebuilt so we figured out how to rebuild them in house, it's been working really well for us.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I thought a lifter is only rock solid when hydro locked? Perhaps I don't understand correctly...?
  23. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Sorry I didn't see this. I'm 100% positive a good bronze valve guide can be made locally by a company like CHE precision.
    The main hold back is I don't want to be experiment on customers cars with internal engine parts, my personal car already has Steel valve guides. I've talked a few customers out of doing it to avoid headaches when selling. Your average buyer isn't educated enough to know it's better, they will just think it's a loose end and pass on the car. Plus the steel guides never ever have issues so why even bother taking another path? We service a few 100k + mile 360s with no valve guide issues, it's proven to be reliable.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #74 Dave rocks, Dec 15, 2016
    Dan, respectfully, I don't believe this is correct. I happen to have my 95 B lifters out and this was on my list to get into.
    I had a little time last night and I check a bunch of mine. Some are rock hard while most I can push the piston and get movement. So out came a small container I filled with oil and submerged the lifter. I tried to pump the piston under oil and no change so I proceeded to take one apart. (One I could move). I'll admit, I used the barbaric method of slamming the lifter to a block of wood to get the piston out (I will be making a tool).
    I took it totally apart to inspect and understand how it works. This lifter was clean, no varish so to speak. I'm confident it did not need any rebuild. Using the check valve and a small pick to push it open (very light spring), I proceeded to charge the piston with oil and then reassembled. When done, rock solid.
    So I think many were soft because the oil had drained out which I think is normal. Before removing the cams, remember all lifters will be in different positions relative to the oil fill port in the head.
    EDIT: these lifters have no seal per say, they are just close tolerance metal parts. The piston has a c clip type ring on the od which may help seal and just add friction to keep the assembly together.
    More to come.....
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,725
    Lake Villa IL
    Dave,
    Basically it is as you describe. If when the engine is shut off a lifter is resting on the base circle of the camshaft, it remains filled with oil and remains -solid to the touch.
    If it is resting on the lobe (valve in an open position) the valvespring pressure acting on the lifter squishes the oil out over time. Upon disassembly the compressed lifter extends but is no longer filled with oil and -squishy-.
    In a running engine of course they are constantly filled with pressurized oil/cycling so they do not compress.
