348 - Brake Pump Runs before startup but won't run AFTER startup! | Page 4 | FerrariChat
348 Brake Pump Runs before startup but won't run AFTER startup!
Discussion in '348/355' started by seabass23, Jun 7, 2023.
  1. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    OK took me like 5 minutes to figure out what I'm even looking at. I have a NA car and there is nothing remotely like that. No factory wiring would be like that. I wonder of someone had one of those 355 type grills with different tail lights on there then spliced back the originals before selling.
  2. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    This is the front light module, not the rear.
    It's definitely not factory wiring but it MIGHT be dealer wiring. Although the Ferrari wiring diagrams seem to lump together CAN and US, I believe there are differences. Specifically, the always-on daytime running lights (DRLs) which are a requirement in Canada but not in the US. The Ferrari market in Canada was microscopic in the early 90s so there is a distinct chance that the dealers were responsible for the addition of the DRL relays and the modification of this wiring.
    Although it looks like a hack job, I see some method to the madness. For example: according to the Ferrari wiring diagram, the pink wire is for the fog lights. In my case, it seems to have been repurposed to run the DRLs, thereby eliminating the ability to have front fogs (and no longer needing the bulb).
    It would be wonderful if someone else with a Canadian-spec car (with DRLs) could confirm how their lights are configured (Stalk positions 0, 1, 2).
    Qavion likes this.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Definitely good to compare, definitely read all kinds of unexpected wonky issues when wiring has been altered on these cars over the years, best of luck!
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Thinking, I think I recall seeing the owner manual (not WSM) outline the stalk positions and lights, is it possibly in the Canadian manual, I have seen the Canadian owner manual online somewhere.
  5. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    Good point, I have my owner's manual in storage. I will dig it out and see if it is Canadian-specific.
  6. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,609
    Ian Riddell
    Ooops... my mistake. Corrected diagram:
    seabass23 likes this.
  7. Qavion
    Feb 20, 2015
    14,609
    Ian Riddell
    Maybe try posting on the Canadian forum to see if you get a response? You can use my graphic to make things easier for them to understand.
  8. Qavion
    Feb 20, 2015
    14,609
    Ian Riddell
    Yellow/red is also used for low beam headlights
    I have no idea what the dual voltage source is for on each light (unless the bulbs are dual element). But why would you need dual element bulbs for parking/marker lights?
  9. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    I think they are dual element. That's how my signal lights work when the lights are one (amber flashes dim to bright)
  10. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    Some time ago, I bought a 1984 BMW E30 which was an import from Japan to Malaysia. The front amber indicator lamps had dual filament, 5/21W, bulbs and the lamps operated as marker lights at 5W (dim amber) and as flashers (21W), flashing from dim to bright amber.
  11. Qavion
    Feb 20, 2015
    14,609
    Ian Riddell
    I've seen this same dual function on the Ferrari rear lights. I didn't know it was the same for the front (Canadian) lights.
    The 348 front lights seemed to be grouped into
    US & Canada
    Japan
    France
    ROW
    It seems odd that Ferrari would provide a relay holder for the daytime running light relays, but then require aftermarket wiring to complete the transformation.
    And why wasn't the other relay clicking? Are there two relays for left and right daytime running lights or do the relays have different functions?
  12. m.stojanovic
    Dec 22, 2011
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    The wiring inside the front lamp shown by Matt is not aftermarket but done in the (lamp) factory. I happen to have a new spare lamp (right, Carello) which I bought on Ebay without checking about the different versions. Now I see that it is actually for the Canadian market.
    The reflector (I have removed the ribbed plastic cover from the fog light segment in preparation to convert the lamp to Euro):
    The cover:
    Wiring in my original Euro lamp:
    Qavion likes this.
  13. Qavion
    Feb 20, 2015
    14,609
    Ian Riddell
    I see the inboard lower lamp doesn't have a round bulb. I don't understand how the Euro/ROW and US/Canada can change the function of this lamp.
    Do you think the USA diagram has mislabelled the lower lamps?
    Do both amber lights (top row) flash during turns on Canadian cars?
  14. m.stojanovic
    Dec 22, 2011
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    I would not be surprised (also, the dipped and main beams, C and D, are screwed-up). Anyhow, the two bulbs in the lower section of the lower lamp are identical on Euro - halogen H3 (not H1 as stated in the manuals) so it is easy to swap between fog and flasher, just swap the spade connectors inside the lamp. Looking at the back of the lamp, the two lower bulbs (fog and flasher) can be easily recognised as H3 because they have "pigtails" with male spades whereas H1 bulbs have the male spades directly on them. My Euro lamp:
    As for the US model, I do not know. Does it have two (halogen or other) bulbs in the lower section of the lamp or only one bulb, like the Canadian?
  15. Qavion
    Feb 20, 2015
    14,609
    Ian Riddell
    Ahh.. I (previously) thought the keyway on the inboard lamp reflector meant a spherical bulb and no interchangeability. Also, I thought the reflector would create a different pattern. Now I have to go back to the drawing board.
    I thought the wiring coming into the lamp assembly on the two "factory plugs" might be common on all types, but there is that yellow/red wire coming in on the Canada car.
    Why it goes out again to the 3rd plug, I don't know. Could yellow/red be the parking light colour and the wiring going out to the rectangular side marker?
  16. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    Oh wow, absolutely identical! Thanks for solving that Miro.
