News
Broke off the float idler pin arm of 40DCNF carburetor
Discussion in 'Technical Q&A' started by christopher, May 3, 2009.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,131
    Ontario California
    Christopher
    #1 christopher, May 3, 2009
    Hey Guys,
    Has this ever happened to you?
    While rebuilding the carburetors, I dislodged the float pin and the little pinch arm broke off……Bummer last carburetor to be rebuilt too.
    My question is, what can I do to fix it? Since the arms will be exposed to gasoline, how should I get this repaired? Welding, cement…. Any ideas.
    Thank you very much…
    Chris.
  3. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,761
    Midwest
    Brian
    I should have a new top here, PM me, I will check on stock and price.
  4. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    I have repaired that problem many times on motorcycle carbs
    by drilling 2 small holes and using a lap of safty wire to hold float
    pin in place. Has always worked fine.
  5. christopher
    Nov 29, 2003
    1,131
    Ontario California
    Christopher
    Thanks for your advise, I may have to resort to that.
    Thank you,
    Chris.
  6. christopher
    Nov 29, 2003
    1,131
    Ontario California
    Christopher
    Did you get a chance to review the PM thatI had sent you?
    It looks as if the later weber carbs has somewhat of a very light green-ish finish to them, I'd like to try to mirror that if possible.
    Please let me know what you might have available.
    Thank you,
    Chris.
  8. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    806
    Arizona
    Jim
    If you decide to try an epoxy to repair it I have used JB Weld in Holley fuel bowl. Fuel does not effect it at all.
    Cheers Jim
  9. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,761
    Midwest
    Brian
    Have one top, unfortunately not for 308 style. Check with Pierce Manifolds in CA.
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I bet Mark (mk e), could weld it up like new?
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    I have done what Larry suggested many times and it provides a lasting repair. Use the thinnest stainless safety wire and you will be fine. Epoxy will not hold up to the constant fuel fumes.
  13. christopher
    Nov 29, 2003
    1,131
    Ontario California
    Christopher
    I actually found a nice carb top at G.T. Car Parts...Bill "hooked me up" with one for about $100.00. I couldn't argue, he's ALWAYS come in for me.
    Just one question from you experienced guys, the brass tubing the screws into the housing, do you need to use a bonding agent (plummers tape), or can you just screw it in as is???
    Thanks, Guys,
    Chris.
