Building a slightly tweeked 2v drysump motor | Page 6 | FerrariChat
Discussion in '308/328' started by duck.co.za, Nov 7, 2009.
  1. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Oh well , motor fired instantly !!! BUT there is a water leak in the ally pipes front to back !!! Got to lift the motor to get them out !!!!
    Chris check them before you put your motor back !!!!!!!
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Oh man that's bad luck. At least SHE RUNS! Congrats!
  3. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Thanks Jack , could be worse . Think I should make new ones out of St/St ?
  4. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Thanks for the heads up Dave.
    Congratulations on getting her started. :)
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
    Glad it fired. Best not to make it more trouble than it already is. Change the hose and you're set. No need for st/st although it is a neat idea.
  6. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    It seems not to be a hose it's the ally pipes ?? They are busy taking them out .
  7. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    An actual pipe has a crack in it? Well, I suppose it's not uncommon. Two of my pipes have welds on them probably from the same thing. Welding the crack is probably the easiest way to go. The welds on my pipes have never gone bad.
  8. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    We will see what's up when we get them out , should be tomorrow !!
  9. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    That's a very sanitary looking engine bay. Now for a stupid question: what's the textured stuff I've seen sprayed all over the engine bays and chassis on these and many other European cars? My initial guess is some kind of rust proofing, but it looks like it'd do more harm than good..
    Rick
  10. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Why use stainless, other than that it would probably be available more easily?
    Also, be very careful with the routing of those braided hoses: they'll 'saw' through anything they touch. Personally, I don't like them much; the braiding has advantages, but it also masks where possible leaks originate from, and prohibit visual inspection of the hose. YMMV.
    Hope to see you with the car in Simon's Town soon!
  11. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    #136 duck.co.za, Apr 13, 2011
  12. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    223 at the wheels. That is fantastic. Congrats to you
  13. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    No No corrected flywheel .
  14. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Dave, finally you drove the car? Sweet!
    Now go put some miles on it, get everything adjusted properly and enjoy. Ou Kaapse Weg will never be the same:)
    I'm sure that after the long period of inop, there will be plenty more chores, but is she behaving?
    2 tips:
    1)
    Get a good fire extinguisher
    2)
    Check the dates on your tyres, replace as needed.
  15. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Thanks Jack . Fire extinguisher serviced . Tyres don't ask !!!! they are on the list
  16. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I asked this on the 'other' forum as well. Curious what your leakdown and cranking compression is now as well as the bore size
  17. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Hi John
    Bore size was 82mm . Leakdown and cracking pressure haven't checked . Once the motors got at least a 1000km on it and your jets have arrived . I'll take the deck lid off and spend a day on the dyno fiddling . Luckly I have unlimited access to a rolling road . I'm impressed how much bottom end the motor has . Things start to really happen at about 4500rpm , but the low speed tractablity is great . So far very happy
  18. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I love threads like this where there is a happy ending. I can't imagine the smile on your face! Keep us up on what's what.
    For comparison, I have (at 1000ft elevation) about 175lbs cranking pressure with the intake valve closing at a late-ish 56 degrees BTDC as opposed to stock US timing with early cams which is 48, and Euro which is 50.
