News
C S paddles on 355
Discussion in '348/355' started by ferraridriver, Jul 16, 2008.
  1. ferraridriver
    ferraridriver F1 Rookie
    4,032
    Bay Area Calif.
    Dave
    #1 ferraridriver, Jul 16, 2008
  3. 285ferrari
    285ferrari F1 World Champ
    Sponsor
    Sep 11, 2004
    19,922
    Southern Md
    Robbie
    Other than the longer up paddle--Is there any difference??
  4. ferraridriver
    4,032
    Bay Area Calif.
    Dave
    The down paddle is a half inch longer too, main thing is appearance, no chips and I think they just look better.
    Plus, I was getting bored :D :D I put the European clear front turn signal in with amber bulbs too.
  5. Ricambi America
    Sponsor Owner
    ;) I guess I was one of "they", and am happy to be proven wrong!!
  6. ferraridriver
    4,032
    Bay Area Calif.
    Dave
    It’s not a simple “bolt on”
    What I did was bolt two paddles together with #8 countersink flat head bolts and nuts with the 355 paddle on top of the CS paddle then carefully cut off the excess. My sander has an idler wheel that is about the same radius as the shift paddles so I simply sanded the radius, and bevel. The notch and screw holes are exactly the same as the 355 paddles.
    Piece of cake :D
  8. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    I think it looks great. Found a set of CS paddles on ebay the other day but didnt know if they would fit.
    Can you post a few more picture on how you did it?
  9. 355newbie
    355newbie Rookie
    Jun 23, 2006
    27
    Looks good, nice touch
    Are they from a 360 ?
    Also do you know the part numbers ?
  10. cicatrix
    cicatrix Karting
    Sep 9, 2005
    223
    USA 1
    can you try to snap a picture of what the other side of the paddles look like mounted? If I read your post correctly, you said you bolted the CS paddle to the 355 paddle?
  11. ferraridriver
    4,032
    Bay Area Calif.
    Dave
    #9 ferraridriver, Jul 22, 2008
    No, what I did was to bolt the two paddles together to get a cut line on the CS paddles. It was easier to trim the CS paddles back to the size of the 355 paddles when they were overlayed so the top one(355) acts as a guide. Once trimmed/sanded, they were separated and the CS paddles bolt on the same way the 355 paddles were.
    Sorry, I didn't bother to take pictures, but here is a very rough sketch of what material needs to be removed. the holes and recess on both paddles are exactly the same.
    Available from Ricambi
    http://www.ricambiamerica.com/product_info.php?products_id=262669
  13. cicatrix
    cicatrix Karting
    Sep 9, 2005
    223
    USA 1
    oh ok, gotcha. Thanks.
  14. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Looks really good, and from what it seems not that complicated to do!
    I ordered a set of paddles from eurospares and will try it out next week, thanks for the tip :)
  15. tactical
    tactical Guest
    Jan 23, 2008
    857
    They look fantastic mate:D I always love a myth breaker and a do'er. Your clearly a man that does, instead of talking fictitious theorys. Good job and thanks for the heads up on the conversion;)
  16. CRAIGF355
    CRAIGF355 Formula 3
    Nov 13, 2005
    1,018
    NJ
    CRAIG ANDERSON
    Sweet They look great to bad Ferrari did not do that from the factory any way I still do know why Ferrari just don't make them a like the f430 challenge long so you can shift up or down when the wheel is some what turned.
  17. 285ferrari
    Sponsor
    Sep 11, 2004
    19,922
    Southern Md
    Robbie
    WOW---Typical Ferrari parts, I figured they would be $$$$---Daniel has them quite cheap!!! I think the stock 355 ones are more than that..
