Cam / Bucket valve clearances | Page 2 | FerrariChat
Discussion in '206/246' started by yakxx21, Aug 4, 2014.
  1. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,239
    Norfolk - UK
    Tony
    Not sure I follow but the factory spec remains the same in all cases, why would it change?
  2. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Shape of take-up ramps, designed maximum lift are a couple likely reasons that clearances are recommended to be different from the OEM cams. It should be noted that there would likely be a bit of clatter at those settings.
  3. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    its probably common knowledge but I found a volvo garage that was throwing out shims from 740 and 940 models that appear to be identical to the Dino variants. I wondered if any other cars used similar?
