355 - Cam phase sensor malfunction | Page 7 | FerrariChat
355 Cam phase sensor malfunction
Discussion in '348/355' started by taz355, May 11, 2019.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes this is why i believe i have no longer any error codes from the ecu. It likely thinks all is good
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Because i had the plug apart it is very easy to put a pin from the back until it touches the female connector while it was plugged in and after i again checked continuity back to the main ecu
    Qavion likes this.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes i did check this as well for both pin 49 and 51 and i did get an open circuit for each
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    The knock sensors will only retard spark not stop it correct?
    What if the cam sensor was faulty (engine did not know timing) and the knock sensor was telling the ecu to retard spark. Would it stop the spark entirely?
    I dont think its designed to do that but thought i would ask
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    The knock sensors have their own OBD2 codes and you don't see those.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yup
    Forgot about the obvious stuff
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Will it hurt anything if i disconnect theinjectors for bank 1 so i am not getting the gas smell?
  8. yelcab
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    Won't hurt anything but you are supposed to get OBD2 codes for injector malfunction. They measure the injector current when the injectors are on.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    My scope setting were, vertical 5V/division and horizontal 5ms/division. Before connecting the scope to the car you should short the scope leads and get it to produce a horizontal trace across the scree. Assuming you arer going to connect o scope channel 1, set the vertical more to Chn 1. Use the black POS knob the adjust the vertical position of the sweep with the leads shorted. Leave the delay switch in Normal position. In the Trigger area I can make out all the settings but it look like Mode is auto or normal. Try auto. For slope it will depends on polarity so try both + and -. trigger level and coupling you will have to paly around with. In the time section you can start with a setting like 50 msec and when you get a signal on the screen you can shorten it to see more detail. Leave the Single and Rest and X-Y buttons out. You can used the POS butting to move the trace left-right. Put the hold knob to off. I don't know what the red knob does buy I suspect it lets you vary the time scale from the dial setting.
    Tough to use a scope if you haven't. Maybe search Google for the user's manual. Never mind. Here it is.
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Sent you a clear email pic John
    Im takng a break on my long weekend for a few hours will get back to this after supper.
    I have the scope hooked up to the good side so i can see what i sho7ld be lookin* for will report back after 6
    Thank you all again for the help
  11. Qavion
    Qavion F1 World Champ
    14,516
    Ian Riddell
    #161 Qavion, May 20, 2019
    Just a thought. The signal from the ECU to the coilpack may be slightly different from John's photo. The 5.2 car sends signals directly to the coilpack, not via a power module.
    There are no oscilloscope displays for the 5.2 in the Workshop Manual, only the 2.7 (which has a power module).
    John's signal is similar to the 2.7 car
    https://www.ferrarichat.com/forum/posts/146616675/
    Perhaps the only difference is in amplitude (height) or current (not shown).
  12. johnk...
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    Forgot I had this. Might help.
  13. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    The diagram on the left of the picture you attached shows what is happening on the Ignition Coil end pins (Pins 1 & 3), not the signal ECU to Ignition Module. The signal ECU to module is this diagram:
    The 355 manual does not but the 348's manual shows the two signals combined - top is ECU to Module, bottom is Module to Coil (pin 1 or pin 3):
    Otherwise, the signal scoped on the Pins 1 & 3 of the Ignition Coil is the same whether it is driven by a separate module or directly by the ECU. In the case of the 5.2, there is also an "Ignition Module", similar to the external one, only it is inside the ECU and part of the overall circuitry.
    Qavion likes this.
  14. Qavion
    14,516
    Ian Riddell
    Thanks, Miro :oops: It pays to compare the 348 and 355 manuals sometimes.
  15. johnk...
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    Doesn't really matter since Grant's car is a 5.2, but to have a better understanding of the function of the ignition module it is basically a switching transistor. It is normally an open circuit. When the ECU on a 2.7 car sends the pulse to the ignition module the switch closes and grounds pin 1 or 3 of the coil. The ECU signal on a 2.7 car is given as a means to determine if the ECU or ignition module is at fault. But we are getting off topic.
  16. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps not too much off topic. In the 5.2 ECU, the "ECU to Ignition Module" signal could be recorded on an oscilloscope if its probe is connected to the base of the ignition switching transistor (there should be two switching transistors for each coil inside the ECU). However, this test would not be easy as the ECU would have to be connected to the car and the engine cranked. If done, the test would determine whether the ignition switching transistor has blown or whether it is not getting the trigger signal from the "clever" part of the ignition circuitry.
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    The first freeze frame is the bank 1
    The second freeze frame is bank 2
    What you do not see is in bank 1 from the freeze frame that the video clearly shows is bank 1 is not near the intensity.
    In order for you guys to see the signal on bank two i paused the video and because it was so intense i did not have to be accurate on the pause to capture the signal.
    Onthe bank 1 i paused it 30 times before capturing the signal.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #169 taz355, May 20, 2019
    This is one video of the good coil in bank 2 slow motion
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    #170 taz355, May 20, 2019
    This is bank 1
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I dont know it kinda seems like its getting a signal just not a strong one maybe??
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I saw apost fromyou Ian but its gone
    Yes that right i should have had atleast 2 plugs fire if that was the case but i dont think it is
    By intensity i mean brightness and height that was noticable.
    I uploaded videos now
    I will test some more tomorrow
  22. Qavion
    14,516
    Ian Riddell
    Sorry, Grant, I posted that message before I saw your video. I had to delete my message and re-assess.
    Ugh.. poor engine. It's running so badly, it's hard to tell if the coils are firing every time on both banks. At this point, it may be best just to fit a new ECU before you break something.
    Did you just look at the waveform on the one pin on each bank's coilpack? Or both wires, 1 & 3?
  23. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Obviously, switching of the coil on Bank 1 is still present but it is rather poor, as is evident from the shape of the section of the graph below the horizontal line. This part of the graph (like a trapezoid, clearly seen on the Bank 2 graph) represents the transistor switching "on" (left vertical line of the trapezoid) and then switching "off" (the right vertical line of the trapezoid) when the spark is produced. The long spike upwards at the "off" point represents the backlash voltage in the primary side of the coil at the moment the current flow through it is cut-off (normal occurrence). The shape of this "trapezoid" on the Bank 1 graph (actually not a clean trapezoid at all) shows that the switching of the transistor is not sharp and clean but "mangled" which cannot produce good high tension in the coil's secondary windings.
    As suggested by Ian, read the other side of the coil of Bank 1 to see if it also poor. This kind of signal (that you recorded on the Bank 1 coil) could be due to a partially failed switching transistor. However, if the other side of the Bank 1 coil shows similar poor switching graph, that would mean that either both switching transistors for the Bank 1 coil have failed simultaneously (rather unlikely) or the circuitry driving the two transistors has partially failed. The transistors can easily be replaced but the driving circuitry is much more complicated. It is now best that you just wait for the second ECU unless you want to go into trouble of opening up the ECU, locating the ignition transistors and inspecting them. You could solder a wire to the base of one of the Bank 1 coil transistors, plug the open ECU in and hook-up the oscilloscope to the soldered wire. This would show you the trigger signal sent to the transistor (the first graph that I attached earlier and called "ECU to Module"). If this signal turns out to be good, it would confirm the transistor failure.
  24. yelcab
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
    So it's hard to troubleshoot from the internet, but if all the settings are identical in the two videos, then you are getting a trigger on the bad bank, just not as often as the good bank. Also the flyback voltage spike is much smaller than the good bank.
    Since you have swapped out the coil packs with no change in performance, I think the fault is in the drivers inside the ECU.
    taz355 likes this.
