News
Camshaft locks
Discussion in '348/355' started by fxdwgs, Jan 26, 2010.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,014
    Sjobo, Sweden
    Bengt
    ......where can we buy a pair of these......
    Something Daniel is sitting on ??????
    //B//
  3. Jamie H
    Jamie H Formula 3
    Rossa Subscribed Owner
    Aug 28, 2009
    2,328
    Puslinch,ON
    Jamie
    for what purpose?
  4. AceMaster
    Feb 6, 2009
    31,039
    Calling a penalty
    I am guessing he means on an engine out service, to lock the cams in place when removing the cambelt so that the timing remains unchanged. I did see one of these once but cannot recall the title of that thread.
  5. ferraridriver
    ferraridriver F1 Rookie
    4,084
    Bay Area Calif.
    Dave
  6. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,328
    Puslinch,ON
    Jamie
    Nice fabrication there. Very handy if you aren't pulling the valve covers or changing the cam seals.
  8. AceMaster
    Feb 6, 2009
    31,039
    Calling a penalty
    nice, very intuitive of you!!
  9. ferraridriver
    4,084
    Bay Area Calif.
    Dave
    You only need to lock the cams when removing or torquing the pulley bolt. It's probably safer to lock them when just changing the belt, but I don't think its necessary if the engine is at TDC. Mine certainly didn't move on their own.
  10. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,014
    Sjobo, Sweden
    Bengt
    .......I will change the tensioners as well...
    //B//
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,145
    chris
    #9 cf355, Jan 26, 2010
    If you are changing the t belts on a 355 you do not need the cam locks as the cams will not move (due to its hydraulic lifters) but on a 348 , with its solid lifters you will need to lock the cams or they may move. Its a shame Ferrari did not copy the NSX design where by the cams are pinned (holes drilled into the 4 cams where you inserted pins to lock the camshafts) for the t belt change. There is no way you can mis time that motor.
  13. AceMaster
    Feb 6, 2009
    31,039
    Calling a penalty
    That would have been an excellent idea
  14. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    5,990
    Bugtussle
    Very nice. :)
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,145
    chris
    having timed a few 355 motors I can say you do not need the cam locks....the hydraulic lifters bleed down and nothing moves when the belts are removed. there is no issue here.
  16. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    730
    NYC
    Check out the 355 episode of Car Fix. They fabricate a simple device to lock the cams.
