Can Koni shocks be rebuilt | Page 2 | FerrariChat
Discussion in '308/328' started by 89 FERRI, Mar 9, 2012.
  1. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    David,
    Over here, beer would be probably more in the spirit of the day...spring time at last! Pleasantly warm and sunny; provided it holds until the week-end, a good time to have the top off on the GTS and go for a long drive.
    Back to the topic: I have two '89, a GTB and a GTS, separated by five weeks on the production line, and by about 500 c/n. Both are ABS cars.
    At the drop of the hat, the "S" is on Konis, the "B" on Bilsteins...
    A guy met a few weeks ago has a "B", twin sister of mine by a few production numbers; ABS also: it is on Konis.
    Go figure!
    Best
  2. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    I wanted to piggyback on this old thread and ask if anyone (or Peter!) can tell me how to remove this one piece(blue highlight arrow)?
    From Peter's photo, it looks like the piece should thread right off. I tried to put the cylinder into the vise to grab hold - it would not rotate and I started to scratch the surface, which kinda upset me. I will soak it with penetrating oil tonight and maybe try some heat on the piece tomorrow. The shock looks to be in good condition for a "1990" date. I wanted to get all the pieces off the shaft so I could finish powder-coating(400F heat) the upper shock tower.
  3. miked
    miked Formula Junior
    Feb 7, 2001
    897
    Cincinnati, Ohio
  4. Du_Man
    320
    Dallas, Texas
    Derek
  5. Du_Man
    320
    Dallas, Texas
    Derek
    Fun Fact that I learned.....the 4 digit on the shock is the "year/month". I can see with my four shocks that they were replaced in 1989/1990
  6. jgmblair
    jgmblair Formula Junior
    813
    Winnipeg, MB Canada
    Jeff Blair
    Put the shock in a vice, put a piece of old timing belt around the foot valve and grab some vice grips to rotate it. No special jig needed, just be careful not to mark the face, it doesn’t take much force to loosen it.
    Du_Man likes this.
  7. miked
    Feb 7, 2001
    897
    Cincinnati, Ohio
    I had the proper wrench for the gland nut but as you found out they are really tight. I secured the lower shock mount in the 3 point hitch's upper mount on my tractor and used a 3 ft pipe over the spanner wrench to break it loose. I have progressed since then as I now have a trackloader to attach stuff to. It doesn't move even when unscrewing a many decades old large hydraulic bottle jack with a 6' pipe on the wrench handle.
    As a side note back in the 1990's I had a co-worker who left the company for an engineering position at the Koni rebuild facility which is local to us near the Cincinnati International Airport. A few months later he took me on a tour of the shop and I watched the put shocks in a lathe and cut them apart with a parting tool. They welded them back together later in the process. I'd rather disassemble them in the "normal" way.
    My shocks were clogged with rubber crumbs from the rod seal(s) in the gland. My shocks were 1977 vintage which just used a stack of plumbing washers compressed by the gland nut, I modified my gland nut to accept a regular oil seal like Koni went to sometime after my shocks were made. I replaced the oil with motorcycle fork oil, there are a multitude of viscosity's available at any motorcycle shop.
  8. Du_Man
    320
    Dallas, Texas
    Derek
    I will look into the motorcycle fork oil.....I was researching the "AW32 hydraulic" oil and which quality one to use.
    The front shock shows needing 8 ounces, and the larger rear shocks needing 10 ounces.....
  9. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Put the shock in a vice, put a piece of old timing belt around the foot valve and grab some vice grips to rotate it. I spent a week with Jeff Leblond in Phoenix rebuilding a few sets of Konis. You can replace the internal components and lubricant but setting the travel and rebound needs to be calibrated to specification.
    Du_Man likes this.
  10. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,077
    someone in the vintage section posted that Koni USA changes the orig design somehow.
    Du_Man likes this.
  11. Du_Man
    320
    Dallas, Texas
    Derek
    Before disassembling, I counted 2.5 turns for the rotating bottom piece (with the ears)....I know there is another post that explains how to set the adjustable soft to hard setting by rotating the collapsed shock.
  12. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Good that you took note of that but my point was you will have no way to determine if the shock is operating at the proper compression or rebound specifications after you replace the guts and oil. After spending a week in Jeff’s shop I can honestly say you cannot DIY rebuild the shocks “properly”, I did two sets and all 8 needed to be opened up and “tweaked” after putting it on the dyno to observe its compression and rebound characteristics! Once it’s in spec you can make them a bit softer or firm by the adjustment you noted.
  13. Du_Man
    320
    Dallas, Texas
    Derek
    Thank you, Jeff, for that info and guidance. I will change the oil, clean the orifices, and powder-coat the bodies. I will probably send them to Koni for a dyno test. I wish there was a local dyno service!
  14. jgmblair
    813
    Winnipeg, MB Canada
    Jeff Blair
    Send me a private message and I will share the correct paint code with you.
  15. Du_Man
    320
    Dallas, Texas
    Derek
    I started my hand at powder-coating the suspension parts and the shocks/springs. It's been a fun learning process. From my research, the Koni shock color is RAL2002...it seems to match well with the original paint on my shock. I have some new Koni stickers from eBay to apply later.
    Edward 96GTS likes this.
  16. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    210
    CT
    Anthony V Rapuano, Jr.
    Believe Chevrolet engine orange is also a pretty close match to the Koni shock color.
    absostone, eurocarguy101 and Du_Man like this.
  17. Imatk
    Imatk Formula Junior
    May 6, 2007
    766
    If anyone is interested in a set of front and rear shocks to rebuild I have them in boxes. I replaced mine rather than rebuilding them.
