Can someone take a measurement for me please? | FerrariChat
Discussion in '456/550/575' started by Newman, Jan 25, 2020.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    Could someone measure the height of their engine from the center of the crank pulley bolt to the top of the intake manifold? Thinking of another engine retrofit project.
  2. franschman
    franschman Formula Junior
    Dec 18, 2017
    352
    Holland
    Bart
    At the front to fthe engine about 420mm, in the middle (intakes) about 30mm higher.
  3. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Thank you
    So from the center of the crank bolt to the highest point of the center intake manifold its 450mm? IF so I'll assume the 456 would be 420mm. Leaning more to the 456 for a better fit.
    Just did a calculation, thats 16" which can't be from the crank center bolt. Should be longer.
  4. franschman
    Dec 18, 2017
    352
    Holland
    Bart
    Sorry, forgot to say I took measurements from my 456, which has a different (lower) plenum compared to your pic.
  5. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Thats okay. Just wanting to make sure the measurement is from the center of the lower most pulley to the highest point on the engine (roughly)
  6. franschman
    Dec 18, 2017
    352
    Holland
    Bart
    Just measured again. From the center of the crankshaft to a piece of board laying on the black covers where they say Ferrari 456 is 450mm. That part seems parallel to the crankshaft. The step in the black covers just aft of the middle is about 35mm, so in total the height of the engine above the crankshaft is 485mm
    If you are really tight you may skip the black covers and replace the fuel pressure regulators under the domes.
    Newman likes this.
  7. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Thanks again. I just made a measurement on my 400i and its roughly 16" as well. I expected it to be 18-20" so sorry for making you measure again. It means the engine can fit and still run the stock 456 intake manifolds. This is good news.
