Can you buy an F50 engine? | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by ponyprancing, May 10, 2018.
Tags:
  1. ponyprancing
    ponyprancing Rookie
    Jul 24, 2017
    16
    Hi all,
    Is it possible to buy an F50 engine from Ferrari?
    If so, how much would it be worth?
    Thanks in advance!
  2. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Complete crank case on its own is £20k, no complete engines showing, but I imagine they have a few crated ones still for special customers and to rebuild any phoenix cars. There was a full used engine in Europe a while back for around £50k.
    I bet a new old stock engine could be found outside of the Ferrari network as well.
    ponyprancing likes this.
  3. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Why not ask Ferrari themselves?
  4. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    I just have to ask... why?
    For an F50?
    For a project?
  5. ponyprancing
    ponyprancing Rookie
    Jul 24, 2017
    16
    For a possible future project!
  6. ponyprancing
    ponyprancing Rookie
    Jul 24, 2017
    16
    Thanks for the info!
    Sounds close to Enzo engine price.
  7. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The F50 motor is not the most powerful v12 for a project, the most affordable bang for your buck at the moment are those from the 599 and FF, amazing engines for the money. The 575/612 is a well engineered and still modern motor as well.
    ag512bbi and ponyprancing like this.
  8. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,884
    Cape Town,SA
    Jacques
    Would be interesting to compare the weight of each engine.
  9. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,410
    FL
    Tipo F130B from the F50 appears to weigh 198kg. The F140 engine from the Enzo and used in the later V12s is 225kg.
  10. Ferrari 360 CS
    Dec 4, 2004
    6,884
    Cape Town,SA
    Jacques
    Interesting, I would have thought the weight saving would have been more in favour of the F50, then again it does have a cast iron block.
  11. Red Sled
    Red Sled Formula Junior
    To me the F50 driving experience is as close to perfection as I have had, but if there is one aspect that would improve it, it is another 75hp. The chassis easily feels like it can cope with more. However, the added downstream weight (e.g. stronger transmission) might have precluded it.
    I would be surprised if a new engine can be had today for £50k given that the factory has none (apart from the display one), and I know of at least two cars in need of a new engine.
  12. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I didn't realise the F50 had a cast iron block! wow there must be some impressive weight saving of other components to make it lighter than the later alloy block v12s like the 599. The bare alloy block from my 575 engine was just about practical to lift by myself, a cast version would be like the anchor of the QE2!
    Just double checked and I made an error about the £50k engine, it was from an Enzo not an F50 sorry
    https://www.autoevolution.com/news/ferrari-enzo-v12-engine-shows-up-on-ebay-88095.html
  13. BMW.SauberF1Team
    Dec 4, 2004
    14,410
    FL
    It must be a pretty compact engine to still weigh less with cast iron. I know the displacement figures don't always correlate to physical engine size, but the F50 engine is 4.7L whereas the Enzo and later are 6.0 and up so I bet physically the newer V12s are larger.
    I was unable to find the engine weights for the 550/575, but maybe Terry can chime in here. He probably knows the exactly weight of each 550/575's engine by s/n as it left the factory. :)
  14. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    My only experience of cast versus alloy block is with the Cosworth YB. The last of the factory cast iron blocks weighed in at 55kg bare where as the later aftermarket alloy blocks are 22kg and that includes extra material to further strengthen the block.. I would assume similar weight reduction % applies for most applications though.
